Help needed with 2007 turbo radio
Old Mar 27, 2014 | 10:45 PM
blue12c's Avatar
blue12c is infamous around these parts
My first post here, hello everyone.
Does anyone know of an easy and inexpensive way to somehow link up a USB to my factory sound/nav system, or direct aux jack, so that I may play music through the factory stereo system.
I have tried one of the adapters that runs through the cigarette lighter, and tunes into an FM station, but sounds like **** with static.
Below is a pic of the radio nav that is in it (bone stock). It appears that there are no aux jacks or settings on the system to do this
Old Mar 28, 2014 | 12:05 AM
roybotnik's Avatar
roybotnik is just really niceroybotnik is just really niceroybotnik is just really niceroybotnik is just really niceroybotnik is just really nice
Unfortunately you have to purchase an addon that costs $500+ to do this. The most commonly used is the dension 500sbt, but it is known to be problematic.
You might be able to find a used tooki ipod adapter and then use a 3.5mm to ipod connector (this is what I'm doing until I replace the PCM). Or the newer version with aux in
Edit: Here's one on ebay: http://www.ebay.com/itm/NAV-TV-OPI-P...item3a8d97a21c
But no, there is nothing straightforward that I know of.
Old Mar 28, 2014 | 07:56 AM
Winnilaker's Avatar
Winnilaker has a spectacular aura aboutWinnilaker has a spectacular aura aboutWinnilaker has a spectacular aura about
I had a navtv, still have it in a box somewhere. Allowed somewhat control of iPod through PCM.
http://www.navtv.com/product/217/mos...eShowProduct=1
But they are not that great in quality. I ended up replacing head unit AND wish I did that in the beginning, so much happier.
Old Mar 28, 2014 | 08:36 AM
roybotnik's Avatar
+1, can't wait to do mine.
Old Mar 28, 2014 | 09:22 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
where are the head unit replace threads? Searching finds more irrelevant then revelevant.
Whats the easiest way? Most-hur or repalcing the amp?
Old Mar 28, 2014 | 09:43 AM
Winnilaker's Avatar
I did with MOST HUR and it was pretty easy. Here is my post to my installation
https://www.6speedonline.com/forums/...ml#post3815187
Old Mar 28, 2014 | 01:53 PM
blue12c's Avatar
Winnilaker: is it possible to get a good pic of your system instal, the video is very dark; do you use stock Porsche parts for the "framing" and stuff, or is it an aftermarket plastic frame?
Old Mar 28, 2014 | 02:12 PM
roybotnik's Avatar
It's aftermarket, you can buy an install kit here:
http://www.suncoastparts.com/product...tT_electronics
Al and Ed's (a sponsor on here) will also put together a package w/ pre-wired harness and stuff.
Old Mar 28, 2014 | 02:50 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Happy to answer q's on Dension's top shelf 500SBT for you anytime. 'Problematic' is not an across-the-board descriptor that applies. If installed and setup correctly, it brings ipod, bluetooth (streaming and calls), aux and usb to the fiber optic loop and does it quite well.
Reach out with any questions anytime.
eric@bumperplugs.com
Old Mar 28, 2014 | 07:58 PM
Winnilaker's Avatar
My car is up on my lift, will have to get picture later, but it's the aftermarket kit described above. I bought a full package from delray, see my thread link, included every I needed to install.
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Fadi
Aug 21, 2015 03:43 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
