Water leak under rear seats
Old Apr 1, 2014 | 07:01 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
For months I've been wondering why my windows have been fogging up after I park it. Lifted the rear seat and found the carpets wet. Been searching on the forums and have found no conclusive place to start checking.
There is no dampness on the foot carpet but on the seat bowl on both rear passenger and driver. Any clues to start looking for the issues?
2008 cab.
Old Apr 1, 2014 | 10:56 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
I'd check the following:
1. Seal between the top and the body
2. Rear window (my personal bet is it's the top edge of this)
3. Top itself (pinhole/hole/rips/tears)
Old Apr 1, 2014 | 11:49 PM
Jako's Avatar
Thanks. I think I can rule out 1 and 3. Point 2 I think can be a possibility but I will also try the wheel well removal and clean out the trap. I also read there was another drain behind the rear speaker panel. I was searching all over the forums to find the DIY for the panel removal too but can't find anything.
Old Apr 2, 2014 | 06:37 AM
997tt+C63's Avatar
997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold
I had the same problem and it turned out to be the sunroof seal only happened when it rained really hard. Check by unclipping the roof lining from the rear. easy enough takes 2 mins ( pull back towards you) you will see your seal damp / wet if its the case.
Old Apr 2, 2014 | 06:38 AM
997tt+C63's Avatar
Or it can be one of your roof water drain plugs on either 4 corners of the roof. check them if they are sealed tight.
Old Apr 2, 2014 | 08:08 AM
Jako's Avatar
Thanks guys a have a cabrio though. Pretty sure they don't share the same drain lines as the coupes.
Old Apr 2, 2014 | 11:01 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Jako...
See if this helps any??
For the 997, porsche devised a system of drip trays which run against the inner walls of the car, down into a 15mm x 250mmx400mm tray behind the driver and passenger seats (below the carpet insulation) and out a set of narrow drain tubes into a cavity between the body and the plastic inner fender. Silt and other road grime accumulates in a "cake" about 1 inch x 7 inches in this space and can get thicker and thicker as silt deposits.
or maybe this for 996?
DC
Old Apr 2, 2014 | 11:20 AM
Jako's Avatar
Hey Thanks! The problem with schematics is that is hard to interpret. This channel that you are referring to. Is it the one which is accessed through the rear wheel inner wheel lining?
Old Apr 2, 2014 | 05:48 PM
therock88's Avatar
Yeah...Agreed. I think that is the one. I had these references from previous cars. Do not have any better pics or more specifics..but at least that gets you in the ballpark of where to look...
Good luck,
DC
Old Apr 16, 2014 | 10:55 PM
Jako's Avatar
Update - not good. After all the drains were checked and there is still water coming in. Determined the water is coming in from the rear somewhere. Another owner experienced the rear window delaminating from the seal but the shop working on my car said they checked and it isn't coming from there.
They saw water coming in from the rear though and will be proceeding to take off the entire convertible top frame to get behind the rear seat wall. They expect it to be 1.5-2 days of labour.
Not a happy camper at the moment.
Jul 29, 2019 11:13 AM
r_matt_6
Oct 8, 2015 06:07 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
The Oss
Aug 24, 2015 08:19 PM
saline
Aug 19, 2015 12:25 PM
