Changed plugs, coils, exhaust manifold gaskets, car wont go over 13 psi...
Old Apr 23, 2014 | 11:54 AM
DNugget991GT3's Avatar
Guys, i replaced all 6 coil packs, replaced spark plugs,air filter, replaced exhaust manifold gaskets, and the gaskets that are in between the turbo and headers. replaced the o-ring rubbers on each intercooler hose. removed diverter valves to inspect them.. now the car is only boosting to 13 psi, and i get almost no boost under 3,000 and it takes a while to boost...
no CELs, idle is fine. what the hell do u think it could be ?
Old Apr 23, 2014 | 12:26 PM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Have you checked the VTG vane controlling arms?
Old Apr 23, 2014 | 12:33 PM
we checked everything when the car was on the lift. everything looked ok. i wont be able to put the car on the lift until next weekend. ERGH !
Old Apr 23, 2014 | 12:45 PM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
I might be all wrong here but my mechtold me some stuff takes up to ten hours of running to get the car back to normal. This was in reference to IPD and such but it might hold some water. Run it hard for a buit and see if that works.
Old Apr 23, 2014 | 01:07 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
If the car won't boost properly it's likely caused by either the turbos not getting enough air to make pressure (think air leak somewhere in the system) or because the ECU is pulling boost (and probably timing) because it detects a problem and is protecting the car.
A pressurized smoke test will usually reveal an air leak, although minute ones can be awfully difficult to track down, while querying the ECU for Diagnostic Trouble Codes via the OBD2 port can point you in the right direction if this is a "limp mode" problem. DTC's may be present even if there is no CEL. There are many, many potential reasons why a car might revert to limp mode so it's a wise idea to do a complete diagnostic before starting to change parts and "fixing" things that ain't broke. If the car was running fine before you did the aforementioned work, rechecking all of that would be a good place to start and a smoke test could help pinpoint the exact location if something didn't seat quite properly when reassembled. Good luck!
Old Apr 23, 2014 | 01:18 PM
omG what a pain int he *** it was to do plugs. i followed therocks DIY, and had to remove the IC's, the bumper, lowered the motor.. took 8 hours.
Old Apr 23, 2014 | 01:23 PM
ChrisAW's Avatar
ChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to behold
Italian tune up!
Old Apr 23, 2014 | 01:34 PM
^lol
Old Apr 23, 2014 | 01:50 PM
Duff0000's Avatar
Duff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond repute
Keep us posted! check your connections on the intercoolers and the y pipe!
Old Apr 23, 2014 | 01:52 PM
Duff0000's Avatar
also as Emre said check the VTG actuator arms to make sure they operate properly.
Pull the drivers side one down, and push passenger side up. They should close or move again when you release your finger
Old Apr 23, 2014 | 02:00 PM
ok i will. i have a feelings its something with the turbo. we had to remove the actuator mechanism on the passenger side to get to the plugs, and we removed both BRV's to inspect them for cracking.
Old Apr 23, 2014 | 02:40 PM
SamboTT@ByDesign's Avatar
Good luck Steve
Old Apr 23, 2014 | 04:55 PM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
Steve make sure that plastic intake air lines from turbo to air box are push all-way down in the engine compartment.
Old Apr 23, 2014 | 05:02 PM
you mean the intercooler lines ? theyre all the way down. theyre not loose or moving at all.
Old Apr 23, 2014 | 05:35 PM
slawek's Avatar
no the tubs that runs from air box through the engine on right and left side to turbos ,make sure that they are push all the way down and that there is no air leaks
ID:	364885   Click image for larger version
