Alphas on the 997 - anyone have a check list? Advice?
This seem to be a bit more complicated than the 996, since you have to go back to the old-school push-rod actuator style and EBC.
For those who have done it, can you chime in with some advice.
I am thinking of the following:
-I need a line kit from one of the vendors (already in the works)
-EBC to control boost, obviously. Thinking the Plex-Tuning or AMS 1000 setup
-A y-pipe with BPV Bungs
-BPV's and flanges that'll fit
For the BPV's, I figured an IPD y-pipe will allow me to weld in some BPV flanges and attach two (insert brand) valves. I need something fairly small to fit in the bay, not like the huge Tial setups.
I am looking for recommendations from those who have done this. My goal is response, not huge hp. I am after 675-700 wheel with near instant response.
All supporting mods are already in place
Thanks!
Thanks!
I had alpha 30s,intercoolers, injectors and clutch and I made 718@24psi on a mainline dyno which reads low from what I hear. I ran ms109 fuel
Also had inlet pipes
I ran stock y pipe and stock exhaust
You just use wastegate pressure or did you use an ebc?
I also ran mafless. I installed diverter valves into the intercoolers, and used an electronic boost controller. Worked very well!! I got diverter valves and flash from todd @ protomotive
