Real Mods for the 997.2TT
Old May 9, 2014 | 06:52 AM
  #46
webcarconnection's Avatar
webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !
Yes they have build 997.2 Turbos
Old May 9, 2014 | 10:43 AM
  #47
longboarder's Avatar
Originally Posted by webcarconnection
Did a Italia with the old tune too and was bad for him hehehe... I will vid all races that I can and share it with the forum, don't worry
With the tune+plenum on 91, I ran the Italia and McLaren from 40mph to 140mph. It would be nice if you could do the same runs on your pump gas tune and then we could compare the videos.
But you did 166 on the 1/2 mile , right? I believe is a good comparison when I go to our 1/2 mile event on June
Yes my half mile result at the Shift Sector Coalinga airstrip was 166.05 mph.
Old May 9, 2014 | 04:17 PM
  #48
Ok, cool
Old May 9, 2014 | 04:36 PM
  #49
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
webcarconnection you need to look at all the possible bolt-on parts working together as a "system" rather than adding one part and seeing if just that one upgrade benefits the car by its self. For example if you upgraded to larger turbos then they will push out a larger volume of air(and head) and will produce A-hp but if your factory intercoolers are no longer efficient for the new turbos then larger intercoolers will make A-hp + B-hp. But if you use stock turbos and just went strait to a larger intercooler when your factory intercoolers were plenty efficient then you will see no gain. The same can be said with plentums, y-pipes, exhaust and so forth.
Old May 9, 2014 | 05:08 PM
  #50
Mit_Boost's Avatar
Mit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant future
+1, you'll net some HP because of the lower IATs, but an intercooler upgrade is going to be more noticable with the consistency since you'll be running a more aggressive tune. Realistically you could probably run the GIAC full bolt on tune that LongBoarder has, but do not expect the car to run consistenly & heat soak after a full WOT pulls.
Nice finds on the 6MT 997.2s, had no idea they made that car without the PDK.
Old May 9, 2014 | 05:38 PM
  #51
Yeah, most of the time is like that... will see how it goes with my next mod
Old May 9, 2014 | 05:54 PM
  #52
yes I know... It will be interesting to see other options too, I'm gonna use other combo than Champion & GIAC (nothing against them )
I already have COBB, I like the AWE IC's (they are VERY similar of Champion ones) and I bet we can get to the numbers they are getting
LongBoarder; what was your whp and wtq on the mustang dyno?
Old May 11, 2014 | 09:41 PM
  #53
Again no responses... I order the AWE IC's, the race is on... Soon will see how COBB & AWE will do against Champion & GIAC
Old May 11, 2014 | 09:46 PM
  #54
kinkkink's Avatar
kinkkink is just really nicekinkkink is just really nicekinkkink is just really nicekinkkink is just really nice
Can't wait to see the results!
Old May 11, 2014 | 09:59 PM
  #55
Me too
Old May 12, 2014 | 07:24 AM
  #56
501/536 stock. I've never dyno'd with a tune/mods.
Old May 12, 2014 | 08:15 AM
  #57
Ok, when you go let me know... I will use vbox, dyno and 1/2 mile event on June
carbonjim996TT
Sep 20, 2015 08:14 AM
maroli
Sep 15, 2015 07:07 PM
Socalsporty
Sep 9, 2015 10:07 AM
John@SpeedTech
997 Turbo Vendor Classifieds
Sep 6, 2015 08:25 PM
