Protomotive E85 tune
That's exciting to hear. I thought you needed at the very minimum an injector upgrade.
Would you happen to have a log? would be interesting to see the boost curve and afr.
Perhaps with stock injectors the tune isn't as aggressive.
-Jose
-Jose
If you don't do injectors you limit yourself with the amount of boost you can run with the stock fuel system. Basically lose out on a 100whp
My 1000cc injectors is in the mail
I am running stock everything except exhaust and tune with e85. The stock injectors leave some hp on the table but frankly if I am going to do injectors I am going to drop the motor and do rods at the same time.
I will log this weekend....anything parameters you want to see?
start with these:
Engine RPM
Ignition Angle(Actual)
Lambda Bank 1
Lambda Bank 2
Maf
Maf 2
Manifold Absolute Pressure
Short term fuel trim bank 1
Short term fuel trim bank 2
Target Boost Pressure
Throttle Angle
Engine RPM
Lambda Bank 1
Lambda Bank 2
Maf
Maf 2
Throttle Angle
#TeamAIM
#TeamAIM
