9ff 200-300 5,6 s
Old Jun 8, 2014 | 11:10 AM
  #31
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Originally Posted by zl996
I am a customer there since 2008 and already allowed to make 4 cars there.
Everything has always fitted.
From there I have no doubts
And the 5,6 200-300 is a 1200 + HP time. this is a clue for me
Dynorun ist next week.
any updates ???
btw .. is your car laggy ???
Old Jun 8, 2014 | 12:29 PM
  #32
sunset gun's Avatar
sunset gun is infamous around these partssunset gun is infamous around these parts
Thought I had read (here, among other places) that 9FF was in receivership some months ago. Is all well with them now ?
BTW, geez, what a ride. 4.2l, AND boost, AND RPMs. Wow.
Enjoy the ride.
Old Jun 8, 2014 | 01:32 PM
  #33
zl996's Avatar
zl996 is infamous around these parts
Originally Posted by ysfg35
any updates ???
Yes i didnt have the dynorun this week because i get a new clutch.
a Tilton clutch 4 disc Sinter metall (1900 nm)
i had bevor Sachs 3 disc Sinter.
and now next week i have the dyno run when the car is ready.
i will write here the result from the dynorun .
Old Jun 8, 2014 | 01:38 PM
  #34
zl996's Avatar
Enjoy the ride.
yes , since November 2013 with new companny name.
"9ff Engineering "
  #35
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
How drivable was the Sachs 3 disc?
Old Jun 8, 2014 | 03:40 PM
  #36
zl996's Avatar
absolutely terribly
stop and go was a nightmare
like a driving beginner.
and i think the Tilton 4 disc will be much more badly
but there was no other opportunity , to much torque for the sachs clutch
Old Jun 8, 2014 | 05:07 PM
  #37
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
absolutely terribly
lol
cant wait to see your dyno , very curious about the torque
Old Jun 9, 2014 | 08:31 AM
  #38
Mit_Boost's Avatar
Mit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant future
Hi my name is zlatko and i am from germany.
excuse me first for my bad english.
I have tested my first 200-300 time .
without shift. complete in 5. Gear 8400 Rpm.
Its a 997 tt
Presicion PT6766
Car weight 1574 kg (stock)
Assuming your car is still AWD, is it running the OEM AWD drivetrain or have some of the bits been upgraded by 9ff?
Old Jun 13, 2014 | 11:47 AM
  #39
zl996's Avatar
Hi guys i had tuesday the dyno run.
unfortunately, it was very hot at this day.
33 degrees outside . Inside at the hall 42 degrees.
then the dyno was wrong calibrated ,the roll was only to 1000 HP calibrated and so we had 4 runs.
at the 4 th run the dyno was ready.
result 1189 HP
torque 1209 NM
I think with colder Temperature it should have a little bit more power
and sorry for my bad english
yesterday i tried the 200-300 run at the 4 th gear and 1 shift to the 5th
same time
Old Jun 14, 2014 | 05:30 AM
  #40
ysfg35's Avatar
looks great
Old Jun 14, 2014 | 09:08 AM
  #41
CRR's Avatar
CRR
CRR has much to be proud ofCRR has much to be proud ofCRR has much to be proud ofCRR has much to be proud ofCRR has much to be proud ofCRR has much to be proud ofCRR has much to be proud ofCRR has much to be proud ofCRR has much to be proud of
congrats on the car, very impressive. the in-car vid sounds just like mine. when I get my car back, i'll try a 200-300. I should be able to do a 5th gear only pull. 100-200 is 3.20 seconds in 3rd only. 900whp but spools early.
Old Jun 15, 2014 | 06:42 AM
  #42
zl996's Avatar
3,2 s 100-200 ist sick
i will put in 2 weeks Michelin cup Tyres and try a 100-200 run.
now it is not possible with PS 2 tyres. no grip.
your 100-150 mph time is impressive too.
whats your engine power ? 1200 HP ?
i dont know my WHP, in germany we measure only engine power or on clutch
Old Jun 15, 2014 | 09:18 AM
  #43
CRR's Avatar
CRR
thanks. i have never tried michelin cup but am very happy with toyo R888's. 900 is at the wheel on a dynojet. i don't know the engine power. i have 996 gt2 so it's lightweight. best of luck to you!
Old Jun 15, 2014 | 10:00 AM
  #44
TurboRexed's Avatar
TurboRexed is infamous around these parts
wow, double the hp I have on tap in my turbo
Loved the video sounds, and that accelleration is mind blowing
Old Jun 22, 2014 | 09:47 PM
  #45
CRR's Avatar
CRR
so as a follow up, i tried a 200-300 last night in my car with a passenger, in very hot Houston weather and it was 7.1. 5th gear only. My car is GT2 aerodynamics and much down on hp compared to yours, but to me this shows how impressive your time is. I will try again with 4th gear start, no passenger, colder weather but definitely will not break into 5's. Would need 1200+ hp to pull hard at these high speeds. congrats to you, keep up the good work.
