Clutch problem
Clutch problem
I m having a problem about the range my clutch have it is a very short range and the pedal is too high what do i do? The clutch model is spec stage 3+
If your pedal is hard to depress, you will have to replace your slave cylinder and accumulator.
If the pedal is too high, it may be a characteristic of your stage 3 replacement
Check the pentosin reservoir up front in your hood to see if there are leaks around the bottle cap or the below. My car is currently having the slave, accumulator and master cylinders replaced due to my 2.5 clutch replacement and symptoms described above. Alternatively, you can do a GT2 slave conversion.
thats gonna be just the way that clutch engages. solution: get a batter clutch.
#TeamAIM
#TeamAIM
jaehoppa
Oct 22, 2015 09:17 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
