Wheel offset help
Old Jun 21, 2014 | 05:36 AM
tt91185's Avatar
tt91185 is infamous around these parts
Wheel offset help
I'm currently in the market for some new wheels getting sick of my p40's. I was wondering if these specs would work on my 2008 turbo. specs: 20 x 8.5 (et44) and 20 x 11 (et56). I'm lowered as well.
Thank you
Old Jun 21, 2014 | 05:51 AM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
front should be ok, rear will require 15mm spacers and still won't be aggressive enough. I'd pass if i had to go over 15mm.
Old Jun 21, 2014 | 07:35 AM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Originally Posted by tt91185
I'm currently in the market for some new wheels getting sick of my p40's. I was wondering if these specs would work on my 2008 turbo. specs: 20 x 8.5 (et44) and 20 x 11 (et56). I'm lowered as well. Thank you
Even with a 15mm spacer in rear fronts are still aggressive relative to rear. With 44 up front target 33-35 in the rear
Old Jun 21, 2014 | 07:40 AM
MrMiggy's Avatar
MrMiggy is a jewel in the roughMrMiggy is a jewel in the roughMrMiggy is a jewel in the rough
Let me know when you make a change. I might be interested in your HREs.
Old Jun 21, 2014 | 07:41 AM
tt91185's Avatar
Will do they are in excellent condition and just put new rubber on the wheels that only have about 150 miles on them.
Old Jun 21, 2014 | 07:55 AM
kchu221's Avatar
kchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond repute
so what is the ideal specs? im actually about to order my new wheels too and the specs are 19x9 +52 front and 19x12 +50 in the rear. will that sit flush or do I have to add spacers in order to make the wheels sit flush on the fenders?
PS. sorry for the thread jack op!
Old Jun 21, 2014 | 10:45 AM
Steve_TT's Avatar
Steve_TT has a spectacular aura aboutSteve_TT has a spectacular aura about
Thank you
Front is fine as noted, but the 11" rear will lead to sub-optimal (IMO) front and rear tire sizes/choices. 11" is too narrow for a 325/25.
I'd suggest getting a 12" rear, which allows you to run 325/25. At 42mm offset it'll yield something fairly flush.
Old Jun 21, 2014 | 10:53 AM
Steve_TT's Avatar
Are you lowered? If so, 52mm front is fairly flush for the 9". For the rear 42mm will be pretty flush for the 12".
Old Jun 21, 2014 | 01:30 PM
kchu221's Avatar
ill be dropped on GMG springs, so should i get like a 5 or 7mm spacers in the rear?
Old Jun 22, 2014 | 10:57 AM
Steve_TT's Avatar
Depending on your taste those wheels might sit too far in so spacers may be in order. I've never used spacers, but read that they can be fine. I generally prefer a rim that doesn't require a spacer tho.
Old Jun 23, 2014 | 10:06 AM
kchu221's Avatar
im like that too... I never use spacers on my cars, but for the Porsche I wanted the wheels to sit as flush as possible to the fenders.
Old Jun 23, 2014 | 07:48 PM
kchu221's Avatar
im about to order my wheels, but the vendor i was speaking with told me that i should run 19x8.5 +40 front and 19x12 +50 rear, which alot of GT2 people run on my 997.1 TT, what do you guys think about this set up? i wanted to run 245/35/19 front and 325/30/19 rear MPSS also...
Old Jun 23, 2014 | 09:11 PM
eurotom's Avatar
Fronts are aggressive rear not aggressive enough
Old Jun 23, 2014 | 09:42 PM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
yup, those fronts are going to stick way out. et45 on stock sized front wheels is pretty flush, so et40 and you're 5mm outside the fender wall
Old Jun 23, 2014 | 10:17 PM
DOOBEE's Avatar
DOOBEE is infamous around these partsDOOBEE is infamous around these parts
I run these wheel and tire specs and use a 5mm spacer in the rear, lowered on KW Clubsport. The fronts do not hang out, but if you aren't low enough they might look that way. They do tuck.
