PCM Failure after Stereo Install
Old Jun 24, 2014 | 01:29 AM
spmmorrow's Avatar
spmmorrow has a spectacular aura aboutspmmorrow has a spectacular aura aboutspmmorrow has a spectacular aura about
I finished installing my stereo tonight and when I started the car Im getting a PSM failure notice on the dash. I have searched the forums and it says it should go away after driving for a little while or try to disconnect the battery again. I had the negative off the battery for the stereo install.
Its late so Im going to drive it a bit in the am... fingers crossed that it goes away on its own. Anyone else have this problem when disconnecting their battery or installing a stereo. (I only installed a replacement head unit so the load on the battery is similar to stock) no fancy amps or anything.
Old Jun 24, 2014 | 06:45 AM
r_matt_6's Avatar
r_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud of
Happened to me a while ago in a similar scenario. I freaked out over nothing lol. First thing that comes to mind when those dash lights appear is $$$. The light turned off before I hit the end of my driveway.
Old Jun 24, 2014 | 12:33 PM
spmmorrow's Avatar
UPDATE: Got in the car this morning and the warning was gone after warm up.... drove to work today with no issues. Looks like it was just from the battery disconnect... I found similar stories when searching the forum but wanted to make sure I was not missing anything.
By the way I LOVE my new stereo, way better than the stock PCM... The look is much more current in the dash now.
Old Jun 24, 2014 | 03:07 PM
tomb18's Avatar
tomb18 is a jewel in the roughtomb18 is a jewel in the roughtomb18 is a jewel in the rough
I too had the same failure.
One thing you need to keep in mind is that there will be many errors in the computer from this day forward. Removing the pcm causes a failure in communications between the pcm and the instrument cluster that shows up in several categories in the computer.
I found this out when I went for service and the dealer told me there were many errors showing up.
They reset the errors but they are now back as I have seen on the durametric. Something to inform your dealer about so they don't try and chase down something that is not really an issue.
audipwr1
Sep 25, 2021 01:31 PM
bobolouie
Aug 26, 2015 12:02 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
00aston
Aug 24, 2015 09:29 AM
