Plenum and throttle body for 997.1 TT. Any use?
Old Jul 10, 2014 | 11:01 AM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Originally Posted by Emmanuele Design
The MAF signal is used mainly as a means of adjusting fuel delivery. You will still run into the factory torque limiters even though the MAF is sensing more airflow.
Sure I guess there is limiting limits for torque/load that you could hit, but I also assume a tuner could leave a little "headroom" in the calibration for future upgrades.
My main point is unlike octane where there is no way of knowing, unless you "ride the knock sensors", the DME still knows about airflow.
Old Jul 10, 2014 | 09:37 PM
gmoney's Avatar
I have the IPD plenum and GT3 throttle body, I did it because my stock hose would blow off all the time, the IPD setup never has, much stronger. Did not feel more power but the prevention of blown hoses = worth it.
Old Jul 11, 2014 | 11:56 AM
matt2ace's Avatar
matt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to all
I did a series of upgrades to my 07 turbo with multiple dyno runs. The thread is linked below. If I had to do it all over again, I would probably go for intercoolers, exhaust, and tune first and then consider intake upgrades. I cannot say that the larger TB and Plenum were an advantage over the stock size, but I do believe that the IPD plenum makes a real difference in air flow efficiency over stock. I also believe that the Y-pipe offers another real improvement in air-flow over stock.
As for CAI.....I am considering going back to stock and doing another series of pulls to see if there is any real difference in power. I do like how it sounds with the CAI vs stock.
https://www.6speedonline.com/forums/...e-results.html
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
shifter_
Sep 8, 2015 12:07 PM
