GIAC+bolt-on 997.2 Turbo S takes on 1,000 HP Ford GT
Old Jul 17, 2014 | 06:18 PM
  #61
Deuuuce's Avatar
Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !
Originally Posted by otis
(remember a FGT has about 10% drivetrain loss versus over 25% in a TT). Otis
I don't think it was making full power either but a PDK is closer to 12%. A tiptronic closer to 18, maybe 20%. No way 25%
Originally Posted by 997ttR
We call it perfect weight distribution and top notch German Engineering.
HP doesn't have an allegiance to any country.
Old Jul 18, 2014 | 11:17 AM
  #62
longboarder's Avatar
Originally Posted by Thenewguy
Why do you like to sandbag your hp? Do you get pleasure from misleading people about your hp then beating them? Serious question, as I don't get why anyone would feel the need to lie about the power they make. If you ask me, I'll tell you the straight up truth. Then good luck to both of us in our race
Fair question. It's pretty common now at the airstrip events to sandbag a little. At first, people were quoting their highest dyno runs and with the higher elevation and higher temp conditions of running out here in the SoCal deserts, people were finding that their cars just weren't making the "optimal" dyno condition power. For example, in optimal conditions, my M3 will do a high 6/low 7 60-130. But at at the airstrip on a hot Tarmac it's lucky to do an 8.0.
So after people started figuring this out, they began to quote lower HP figures. Not necessarily "sandbagging" per se, but factoring in airstrip conditions.
Now GIAC has said to me that Porsche would likely rate my car at 700 hp. Given that manufacturers don't rate the "optimal" HP, and that Porsche tends to be even more conservative than other manufacturers, that 700 may be "sandbagging" a little.
In any event I haven't dyno'd with my mods, so I don't know how much power my car is making...so 600 wheel/700 crank was my best guess based on input from GIAC/Champion. But based on the outcomes of some of my races, it's pretty evident that it's making a little more than 700 crank.
Old Jul 18, 2014 | 11:35 AM
  #63
webcarconnection's Avatar
webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !
How much % do you think our .2's have between whp vs crank hp?
If is 20% my car have 568whp x .20 = 113 + 568 = 681HP
So your 700HP x .20 = 140 - 700 = 560whp???
Old Jul 18, 2014 | 11:38 AM
  #64
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
The results change depending on the format of the formula.
Old Jul 18, 2014 | 11:42 AM
  #65
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
You kinda did that wrong (multiplied your actual wheel vs 20% and divided his estimated crank by 20%). He estimated 600 wheel so 720 at the crank
Not sure if it was the latest and greatest revision, but GIAC has a dyno for 568 whp on 100 octane on Emmanuele Designs website.
Old Jul 18, 2014 | 12:14 PM
  #66
Ooook so the formula is different than mine but Emmanuel Desing dyno similar car but on 100oct and made the same 568 like I did??? Lol
Old Jul 18, 2014 | 12:20 PM
  #67
ecpChris's Avatar
Was yours on 93? I don't remember seeing your dyno
Old Jul 18, 2014 | 01:40 PM
  #68
Here you go my friend
https://www.6speedonline.com/forums/...o-numbers.html
563whp on 93 oct
Old Jul 18, 2014 | 01:48 PM
  #69
Now I have AWE IC's so I have to retune and maybe do a 100oct tune
Old Jul 18, 2014 | 02:09 PM
  #70
Deuuuce's Avatar
Minor point I accidentally put in quotes.
Old Jul 18, 2014 | 05:22 PM
  #71
Thenewguy's Avatar
Thenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of light
GOT IT! Makes perfect sense. A lot different (in my mind) than the UGR folks-and others like them-that sandbag just for the sake of embarrassing people. Like underestimating power by a LOT, then destroying hapless people that walk into the trap. Good race(s)
Old Jul 18, 2014 | 08:10 PM
  #72
Haha thanks yeah we've had some big sandbaggers and jumpers too (guys that will floor it like 2-3 car lengths before the cones) and people figure it out quick and word spreads and then they have no one to run.
Old Aug 7, 2014 | 11:43 PM
  #73
997ttR's Avatar
997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light
Here you go my friend https://www.6speedonline.com/forums/...o-numbers.html 563whp on 93 oct
What Softronic has to say to its clients about this ??
Old Aug 8, 2014 | 11:53 AM
  #74
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
I should add that our Mustang MD500 reads conservatively and we typically base our crank corrections on the wheel numbers we collect. When people compare our AWD dyno numbers to that of a dynojet or a dynapack, they're likely going to think that we're sandbagging the numbers. Even compared to some other Mustang dynos.
For instance, a 997.2TT (non-S) makes about 420whp on our dyno, on 91 octane. We've seen loosely calibrated mustang dynos show 500whp stock for that same platform. This means before tuning, that car is reading 80whp higher (base to base). Is one car faster than the other? Definitely not 80whp faster. The issue is that the tuned whp will appear higher even if the delta between stock and tuned isn't.
Old Aug 8, 2014 | 12:31 PM
  #75
Softronic's Avatar
Veteran: Marine Corps
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
There isn't much too say as when you read the post you will find out the file was an old one made for 91 at the time and for the previous owner several years as I recall prior. The comparison was to a 93 octane tune and new. We currently get around 560 for a 93 octane file and have increased the 91 as well. So basically and older 91 file was compared to a new 93, not a accurate comparison as a new 93 to new 93 would be more realistic.
Best,
Scott
Softronic - Porsche Performance Software Tuning
Faster than a speeding bullet.
Cayman | Boxster | 911 | Cayenne
Many 24HRS Daytona Winners programmed by Softronic! along with 1 lap of America and more.
Porsche Interseries programmed ,World Challenge,PCA,IMSA and others in an exclusive with Softronic..
Porsche PCA racing binary check by Softronic for compliance.
