Race Harness & Roll Cage help
Old Jul 27, 2014 | 02:47 PM
Mario911TS's Avatar
Mario911TS is just really niceMario911TS is just really niceMario911TS is just really niceMario911TS is just really nice
Hello,
So I've been doing some research on Race Harness / Seat Belts for my 997.2 Turbo S, but I'm a little confused.
Do I NEED a Roll Cage of some sort in order to install the Race Harness? Is there ANY way I can do it without a Roll Cage?
And if not, is there a Simple roll cage / roll bar / anything that can make the installation simple for the Harness and not need a roll cage?
Thank you.
Old Jul 27, 2014 | 03:02 PM
GT3 Chuck's Avatar
Administrator
Please don't install a racing harness in a car that doesn't have proper racing seats with eyeholes for the harness as it can result in serious injury in a crash....once you have proper seat/harness you must understand and accept that you will be less safe without some kind of roll protection should the car roll for any reason...the seat and harness will hold you upright and when the roof crushes it will be on your noggin....in my opinion it is an all or nothing proposition but I see plenty of drivers in DE events with harness bars and harnesses without proper seats or roll protection
Old Jul 27, 2014 | 03:21 PM
Mario911TS's Avatar
My car has the Carbon GT2 Race seats from Factory, but I don't know if a roll cage is required.
If it is, what are the best or simplest options I could go for? Maybe something that's just for the belts?
Old Jul 27, 2014 | 04:05 PM
GT3 Chuck's Avatar
Administrator
You don't need a roll cage unless you are going to make it track dedicated...a simple roll bar like the Techquipment or Das will protect you in a rollover and not present a hazard when driving on the street without a helmet....if you are willing to accept the risk you can just use a harness bar and hope you never roll
Old Jul 27, 2014 | 04:09 PM
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
First thing to ask is what are your goals with the car? A lot of tracking? just a few DE's a year? As Chuck stated safety equipment is best thought of as a complete safety SYSTEM. Otherwise it can do more harm than good.
Old Jul 27, 2014 | 04:19 PM
Mario911TS's Avatar
I'll explain a little more;
We do occasional tracking on the car, but we do a lot of canyon road driving. The reason behind wanting the Race seat belts is because even with the Race seats, the stock Seat Belts just don't feel very secure during these drives. You move quite a lot to the front, etc.
I don't want to install a Roll Cage if I can avoid it. Anything that would work in order for me to install the race seat belts would be good. I know I need the bar that goes under the seat for the front, but I'm lost on the shoulder parts of the race seat belts.
Any links to what sort of bar I can use to attach the belts to?
Old Jul 27, 2014 | 04:44 PM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
PM Sent
Old Jul 28, 2014 | 09:02 AM
Mario911TS's Avatar
Originally Posted by yumaverick
PM Sent
Thank you, I'll keep your offer in mind, but I would like to know before I make a decision, if there's any other simpler way than a roll bar / roll cage to attach the belts.
Thanks!
Old Jul 28, 2014 | 09:20 AM
32krazy!'s Avatar
the 4 point rollbar most are talking about use the front and rear seat belt mounting holes. add harnesses with proper seating and your moving in the right direction. without a helmet your risking injury if you roll and hit the bar with your head. if you use a helmet then hans or halo seats are wanted as the helmet can whip your head but the harness holds your body in check
Old Jul 28, 2014 | 07:22 PM
E55AMG's Avatar
^^ Also true. You really need to think this through. As i said, all safety gear is meant to work as a system. A full cage would be insane in a street car - unless you plan on wearing your helmet driving on the street. A harness bar could work, but as mentioned above, harnesses without a HANS now opens up a whole new can of worms.
Not to be an ***, but are you really pushing the car so hard on the street that you need harnesses to hold you in the seat? If so, well... With safety gear, there's usually no middle ground. If you can't do the whole thing, you're often better off with the stock setup. going halfway can be more dangerous than leaving it alone.
Old Jul 28, 2014 | 07:52 PM
GT3 Chuck's Avatar
Administrator
Here is a tip I used to give guys to limit sliding around using stock belts...after clicking in slide your seat forward to really snug the belt...should help
Old Jul 28, 2014 | 09:01 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Autocross tip. Fully pull out your belt. As it retracts it is locked. No slack in the belt, it's fully locked until you unclick it. Common move when autocrossing using stock equipment.
Jul 29, 2019 11:13 AM
alevine
Nov 4, 2015 10:05 AM
turbotuner20v
Sep 11, 2015 12:02 PM
The Oss
Aug 24, 2015 08:19 PM
