335/30 18 Hoosier R6 on 11j rim
Old Jul 31, 2014 | 09:04 AM
Tarasser's Avatar
Tarasser is infamous around these parts
Any experience in such setups?
will this work?
Old Jul 31, 2014 | 12:08 PM
DNugget991GT3's Avatar
will not work. tire is too wide and too short.
305 35 18 is the way to go for width and height.
Old Jul 31, 2014 | 02:09 PM
Tarasser's Avatar
Will try 255/35 18 + 315/30 18
Old Jul 31, 2014 | 02:20 PM
is this for a 997 or a 996 ?
if its for a 997, you'll have a slower car with that setup. less mph in each gear
Old Jul 31, 2014 | 03:54 PM
Tarasser's Avatar
Why should i worry about it?
Old Jul 31, 2014 | 04:27 PM
a 315 30 18 is quite a bit smaller than the factory 305 30 19. your best bet is to run a 305 35 18 nitto nt01 or the like.. i realize hoosier doesnt make a tire in that size.
Old Aug 1, 2014 | 03:57 PM
damon@tirerack's Avatar
Moderator
The 335 Hoosier is 5/8" shorter in than the stock 305 is. It's also designed to be fit on at least a 12" wheel. The sidewalls on the R6 are pretty stiff, it's unlikely you will get the tire on the rim without crowning the treadcap on it. Not a good idea.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 2, 2014 | 04:59 PM
Tarasser's Avatar
Old Aug 4, 2014 | 12:24 AM
MegioN's Avatar
MegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to all
I am using 335-30-18 Drag Radials, they works pretty well
s6spd
Oct 6, 2015 08:20 PM
Oscar 987
Sep 29, 2015 04:57 PM
manfred@loma_wheels
Audi
Sep 26, 2015 07:49 AM
JWrightPNH
Sep 14, 2015 01:15 PM
