On route to a PROPER handling Porsche 997 Turbo
#31
1* Brand new set from a "local friend"? Unless this friend is an authorized dealer, doesn't this mean there will be no warranty from this shock? You are willing to do that at this point?
2* PASM failure could likely be an electronic, not mechanical problem. *If* indeed your car had 3 straight failures (nearly an impossibility in a functioning system), the implication to me is that there is a short or an electronic problem somewhere that is *still* there. Putting in another system could just result in another failure.
3* Honestly, there is something sort of wild about this whole story that confuses me, but regardless, I feel your pain. Best of luck and remember there are 4 non-PASM alternatives that you could move to that likely will solve your problem instantly: KW V3, Ohlins, Bilstein B8, Bilstein B16 PSS10.
2) Cannga - hmmm, "me don't think so". If you've read my notes, and of that opinion - you may need to touch up on the principals of electrical engineering and electrical systems.
3) Not interested after I'v got my suspension set juuuuust right. If it fails again... i've made piece with it. An explosive video will follow: "bilstein shocks vs. .50 cal, at the shooting range".
PS. You'd better like my numbered bullet lists and bolding of text...
...just taking the **** cannga... enjoy the weekend!
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
oddjob142
08-19-2015 12:27 PM
