Cam sleeve slip/repair. What else should I do while engine out?
Last week while driving with my son(in a spirited fashion) the check engine light popped on. Thought it would be the MAF like I experienced in my 996tt, but not the case after a code reading. Dropping car at the dealer tomorrow for the repair; glad I bought the First Mile Warranty!
So, what else should I have them do while lump is out? The car has GIAC flash, BMC, Fabspeed exhaust, and Tubi headers. It's a tip.
1. Forge DVs?
2. New plugs? car only has 16k miles and it's a 2007.
3. Silicon hoses?
4. FVD plenum?
Forgot to mention I have Champion intercoolers as well.
Anything on my list, ymaverick?
Plugs and coolant pipes. The rest doesn't really give you any gains IMO. The intercoolers are solid. Maybe vtg's and a tune? Depends on what kind of power you want.
since the engine is down put on upgraded turbo inlet pipes (talk to member prodigymb, he may have a spare set for a reasonable price). This will help futureproof you in case you want more power later. Are you getting the camshafts pinned or replaced under warranty?
Just to clarify, there are 2 items that can be pinned - camshafts (the 2 intake camshafts) and coolant lines. Warranty will replace camshafts so theoretically this could happen again. I had my bank 2 camshaft replaced under warranty a couple of years ago. So far so good.
