Turbo guys... Anyone running wider tires on OE wheels?
Old Sep 26, 2014 | 06:40 AM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
Have know people with this issues on in warranty cars get rejected on repairs bc they were running 315's in the rear. I would stick with stock to be safe and reliable.
It was his Diff that blew out.
Originally Posted by mcurtisal
From experience, I will never stray from the factory specs on wheels/tires. I bought a pre-owned 997TT Tiptronic with 22k miles that required a new diff/tranny because previous owner ran 305 25 20 instead of 325 25 20. Looked great with more rim showing but total repair was over $25K.
Old Sep 26, 2014 | 09:34 AM
DNugget991GT3's Avatar
whoa
guys
dont let the infamous tire size questions kills brain cells like it did in the 996 forum.
you CAN run wider tires, as long as theyre within spec.
within spec on the 997 means that the rears are slightly taller than the fronts.
a 235/305 set up gives you a rear that is around 8/10ths of an inch taller than the fronts
a 245/325 (oem gt2/gt3) set up gives you a rear that is about 8/10ths of an inch taller than the fronts. so its absolutely fine.
you can NOT run a 245/325 set up on factory wheels. a 12" rear is required.
if doing 20s, you need to be running a 325 25 / 245 30. NO OTHER SIZES (not a 305/25, not a 315/25)
Old Sep 26, 2014 | 09:52 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Originally Posted by Steve K ny
whoa
guys
Not true. In my pics above, I am running 245/325's on factory 11.5 wheels. Installed and recommended for more grip at my local porsche dealer.
Old Sep 26, 2014 | 10:26 AM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Originally Posted by Steamboat
".....18" in 245/40 & 305/35 has the same delta and safe to run and also NT-01's are avaialbel in this size."
Thanks, and yes, the Nitto's seem to be the tire of choice. Now they just have to start making them again. Have also heard the Kumo Ecsta is very good albeit with a short lifespan, ie, about 10 heat cycles before significantly falling off.
A couple more questions: (i) In going to 18's must the car be realigned and re-corner balanced? (ii) Can I continue to use the 19's on the street - mostly just toodling around - or do I just need to stick with 18's for everything? (iii) In going with a 245/40/18 and 315/35/18 setup, are 9" fronts and 12" rears the way to go? Anyone have an idea what the wheel offsets should be? Thanks,
No kidding I've also requested nitto to manufacture a 305/30/19 not sure why they haven't as they have our OEM fronts. 10 heatcycles? Might as well go with Ho-ho's.
As far as alignment I would align my car with car setup for track meaning with the 18' wheels. Yes you can continue with the 19's on the street. I do the same thing except going from 19- 20" 245/315 is not the right config, you want a 245/305. As far as rim width front is okay, a 12" inch rear may make a 305 rear look stretched depending on the tire.
Offsets can be subjective and again dependent upon wheel and tire width. If you stick with an OEM tire set up and OEM wheel widths I consider a Front ET 46 and Rear ET33-36 to be perfect. (independent of wheel diameter)
Old Sep 26, 2014 | 10:32 AM
white
997 turbo wheels are 11 not 11.5
11.5s will be ok on a 325
Old Sep 26, 2014 | 11:08 AM
White Rock's Avatar
white 997 turbo wheels are 11 not 11.5 11.5s will be ok on a 325
Whoops. I assumed all factory wide body rims where equal.
Old Sep 26, 2014 | 11:47 AM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
".....you CAN run wider tires, as long as theyre within spec.
a 235/305 set up gives you a rear that is around 8/10ths of an inch taller than the fronts"
Steve K,
Are you saying that the rears MUST be slightly taller than the fronts i.e., that a slightly taller front would likely not work or cause damage?
The Nitto 01 in 245/40/18 has a diameter of 25.55" & the 315/30/18 25.35" which is less than a 1% difference BUT it is the front, not the rear, that is larger. Thoughts, please?
Old Sep 26, 2014 | 12:14 PM
yes the rears MUST be taller than the fronts. must must must.if its the other way around (fronts taller than rears) you WILL damage your awd system for certain. not to mention causing havok on your PSM/abs.
you would need to run a 305 35 in the rear.
Old Sep 26, 2014 | 12:40 PM
Steamboat's Avatar
Steve, thanks for the advice! They don't make a 315/35/18...sigh.....and the 305/35/18 has a 26.42" diameter per Nitto which is 3.41% greater than the front at 25.55". I thought front to back needed to be <3% delta or is that just street-lore?
Old Sep 26, 2014 | 02:30 PM
thats the size that 997 guys run when when going down to 18s.
im currently at 26.5 rear and 25.7 front (more likely 25.6x because im slightly stretched on a 9" wheel.
no issues whatsoever.
gt2 spec (245/325) is on a lot of 997tts (it will be my setup for next summer). fronts are 25.8 rears 27.2.
Old Sep 26, 2014 | 03:49 PM
Steamboat's Avatar
Hmm, that's a 5.43% delta. Some guys say you can get away with 4%, others say keep it below 3%. The GT2 is rwd which means you can do just about anything that fits in the wheel wells but unless you ditch the front drive train and deal with the attendant problems that brings, that seems pretty radical for an awd setup. What's your thought process or are you just feeling lucky?
Old Sep 26, 2014 | 06:31 PM
i dont know how these percentages are calculated.
but i can tell you that a gt2 set up has the same difference front to rear as a 997tt.
in fact, Champion Motors, GMG,and wheels boutique run their 997s on gt2 sized wheels.
a 235/305 set up and a 245/325 set up are both .8 inches taller in the rear than the fronts, respectively.(.8 and .9 to be exact).
steam, my bad. i meant to type 26.7 for a 325 30 19. not 27.2
Old Sep 26, 2014 | 06:48 PM
pwdrhound's Avatar
Street-lore Dean. Ask anyone to show you documentation from Porsche showing this mythical creature called 3%. You're gonna be waiting a loooooong time... With that said, stick with the OEM difference of 0.8" or so and you'll be fine. Both Nittos and Kumhos are in that ball park, Hoosiers are not. You can also run Pzeros in 245/645-18 and 325/660-18 for mega grip. That's what I'm gonna run for time trials.. Running other than the factory split is a bit of an unknown. It may work just fine running around on the street with occasional full throttle blasts but it's a different ball game running ***** to the wall for 30 min at the track where your diff will be subjected to much higher stress. My $0.02. All of your best performing set ups wil be 18s anyway. That is all you'll find on cups and RSRs even through the 991s.
You won't find a better bang for your buck than the 245/305 NT01s. $1000 and I get 20 sessions on them. At HPR they are only a half second slower than Kumhos or Hoosiers. Kumhos are $1500 and I get 10 sessions. Hoosiers are $1800 and will last about 7 sessions. The math gets ugly in a hurry....
Old Sep 26, 2014 | 07:49 PM
Steamboat's Avatar
"...steam, my bad. i meant to type 26.7 for a 325 30 19. not 27.2"
Steve, that makes quite a bit of difference; the differential is then 3.48%. That seems to pass the reasonableness test (if there's actually any such thing).
John, the problem is there does not seem to be generally agreed upon parameters that confer "safeness" on this topic and as my wife likes to point out, I've already had my Porsche mulligan and can't afford another $20K+ debacle. Insofar as the "math getting ugly", well, that happened some time ago! What a hobby.......Hope to catch a break in the weather and get to the track in October.
Off Topic: Saw where Ryan ran a 2:00xx last Sunday. Was that on the new Super Sports? If so, Simply Amazing!! He's got talent!
Old Sep 26, 2014 | 09:01 PM
pwdrhound's Avatar
That's exactly why I said to stick with OEM diameter ratios. Doesn't matter if it's an 18 or 19 wheel as long as the diameters are pretty much the same as OEM. The October DE will be a good turn out. Hopefully the wx will hold and you can make it.
Yep, Ryan ran on the Super Sports. Those are great tires. From what I have heard they are just below the performance of the Sport Cups but wear like iron. I've driven Ryan's car out there before he put the Super Sports on and it was solid. I'm sure it's even better now. Chris did a great job setting it up and it feels great. On top of that, Ryan is a quick learner and a great driver. I'm betting he'll get into the 59s next time out if it cools off a bit. The time trials on Sunday were fun. I was just very hard to get heat into the tires with only one warm up lap. Take a look at the picture below taken on my second hot lap. On my first hot lap I lost traction at 80mph out of turn 12 all the way to the cork screw. That cost a full second and was a bit hairy. 2nd lap was better as the tires heated up. Fun weekend overall...
[url=https://flic.kr/p/pnjKRX]
