proTUNING Freaks - 997.1 Tial Alpha 3076 Project :)
Old Sep 23, 2015 | 12:43 PM
  #121
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Originally Posted by proTUNING Freaks
35+ degrees or bust LOL
Agreed on C16 except O2s not liking them. Some do last for a while, some have failed next day on some cars NTKs seem to hold up better but that's something to consider on any leaded fuel.
Dzenno@PTF
NTK sensors will live a lot longer than the Bosch sensors in my experience. If you run some unleaded on them after they start to read strangely you can usually bring them back too.
Old Sep 23, 2015 | 12:45 PM
  #122
rix's Avatar
rix
35+ degrees or bust LOL when did your yellow car go NA?
Dzenno@PTF
Of course that begs the question if it really was 35 degrees. I would like to see that on the timing light .
Old Sep 23, 2015 | 12:46 PM
  #123
Originally Posted by rix
I have seen some Ethanol failures, but not on Porsches. I would feel a lot safer on VP Import.
i mean, i am not saying Ethanol is better than VP import. that would be a stupid point to argue. with that said 25 full tank fill ups with VP import are worth about the same as a good used low mile 997TT engine
for me spending almost 40$/Gal is not an option as i like driving my car as much as i can not just to a car meet to swing my d*** around and go home.
as far as C16 goes, E85 will do just as good **with the right fuel system**
#TeamAIM
Old Sep 23, 2015 | 12:51 PM
  #124
rix's Avatar
rix
Not disagreeing with you on power output, but the safety margin of an overly aggressive tune and/or poor conditions (i.e. hot) is less. I'm not trying to rain on the Ethanol parade, I love the stuff. Rather I am just saying to the general board membership who reads this thread be careful it's not $2/gallon VP Import.
Old Sep 23, 2015 | 01:00 PM
  #125
proTUNING Freaks's Avatar
proTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond repute
To be fair, the reason lead is there to begin with is to make it 'harder' to pre-ignite (i.e. start melting/breaking things).
The caveat with E85 is that it won't be a spark knock problem, but a pre-ignition problem. While ethanol has a high resistance to autoignition, it has a fairly low resistance to hot surface ignition. That means if you have hot surfaces in your engine, like hot spark plugs or carbon deposits, it will ignite on those before the spark. This will destroy your engine, fast, but we're talking about certain extremes.
What would I personally pick for a half mile or full mile run for added safety, it'd be a toss between E85 and C16 but if I had to pick one the vote in the end would probably go to leaded fuel/C16.
Dzenno@PTF
Old Sep 23, 2015 | 02:42 PM
  #126
Mit_Boost's Avatar
Mit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant future
The fact is that from our research, outside of claims being thrown around, no one has really shown a meticulous documented approach to their findings around horsepower and torque limits of a stock motor. Many do and have thrown around hp bending rods, some mention HP at the motor some at the rear wheels on an unknown dyno, some mention TQ again without any reference to a baseline making it irrelevant to a reader such as myself trying to understand and connect the dots of what can/can't be done and why.
Side Note -- When/IF you build the motor on this shop car, will you take photos of the rods to confirm the power you were pushing was safe or perhaps a tad bit aggressive.
Thanks.
Old Sep 23, 2015 | 02:45 PM
  #127
Thanks.
Absolutely, but if that does happen we'll know sooner than waiting to open the motor.
Old Sep 23, 2015 | 04:14 PM
  #128
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Originally Posted by Chkmgnt59
Without blowing up is the imperative part of your sentence there. I've seen too many cars with meth failsafes that.. fail. And when they do, the engine is gone. 93 + Meth makes nearly the power of MS109 or E85, but it adds another element of risk to the equation. This car is making great power and great times, but its not some magical formula. This car is pushing the limits of the stock rods, as would a car on E85 be doing with the same mods. Playing the lottery hoping the rods won't bend or fail.
I'm not meaning to downplay that this is a very fast car making great power - but its not some magic formula PTF has unlocked. Its just pushing a car to the limits. The owner of this car most likely expects to build the motor soon, or is prepared to in the event it fails. Otherwise, they're taking a lot of (IMO) foolish risk.
edit: and PTF makes it clear that they will be adding rods/headstuds to the car eventually, and they're logging it constantly looking for the signs of failure. So I want to be extremely clear, I think PTF is doing this properly and the customer is fully informed. I just wanted to point out the amazement might be a bit overblown.
Chkmgnt59,
The above response from PTF is why this pushing of the rods envelop is a little different.
I fully understand where you are coming from and personally do not want to have a 20k engine build either. The point is they are fully documenting their trip to the deep end and IF it all holds together with their careful tuning and testing OVER TIME, we has as a community have found how to make more power reliably on a stock motor.... and with affordable pump and meth for us guys that are paying $750CDN for a drum of E85!!!
I also have a Todd K / Protomotive 63.5 E85 tuned magic (just got car on road and will open another thread with results!), but I am open to solid, documented, reliable companies as that is how a platform grows!
I remember when the MK4 Supra's came out and every one was saying that 600bhp was the limit, but after companies / people kept on doing what PTF and others are doing, they realized you can have 800+RWHP on a stock short block & many even long block reliably(some 30k-60k) IF TUNED PROPERLY!!
I understand TODD K has built more of these cars then anyone (hence why my car is a Proto car), but as a platform we should always be moving forward , learning as we continue to push the platform forward.
Bobby Ali
ba
Old Sep 23, 2015 | 05:07 PM
  #129
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
the danger with stock rods is beating some 60-130 on 3rd and 4th gear where down low torque hit most (i was spiking 2bar+ before i bent my rods), even worse when break boosting but had great succes in 1/4 mile imo way safer cuz you stay in upper gear all the way!was hitting 26-28 psi on top on my a28s with meth hitting 140mph trap
timing play alote and got to be very conseverave around 4000-5000
this is where cilender pressure hit most
if this can help my timing at 4500 was around 12deg then goes 21deg up top and that with meth with 30psi spike to 26-28 psi up top
Old Sep 24, 2015 | 08:04 AM
  #130
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
We turned it up until it literally wouldn't make any more power like you mentioned.
Isn't that also because you have stock heads, cams, manifold and stock displacement ?
Old Sep 24, 2015 | 08:10 AM
  #131
my heads were ported. everything else was stock.
#TeamAIM
Old Sep 24, 2015 | 08:13 AM
  #132
@mtlsp, I'm not sure if you ever got a chance to take your car on a dyno but I can tell you that given where your boost was (26-28psi with spikes to 30psi) and your timing at 12* in midrange you must've been putting down at least least 100awtq if not more more than what we're showing here. Our boost control is doing great and it is smooth without spikes at any load/rpm range and we're in the 22psi range down low with less timing putting down 680awtq on our Mustang AWD dyno.
What tune were you running back then and what were you using for boost control and logging?
Dzenno@PTF
Old Sep 24, 2015 | 08:20 AM
  #133
Thunder915's Avatar
Your trap speed and vbox # as fast fully built 3.8's w/35's but I'm not sure how your car perform on lower boost ( 93 octane )
Old Oct 5, 2015 | 07:56 AM
  #134
Old Oct 6, 2015 | 02:01 PM
  #135
mtlsp's Avatar
Dzenno@PTF
sorry for the late dzenno ,to answer your question i have evom gt700 flash+ eurodyne for fine tuning and logs , i bypassed my oem n75 with an ebc !
without meth only evom flash i was set at 22psi and lower timing it trap 132mph then with eurodyne+meth more boost more timing = 140
i would not be suprise that meth added me close to 100hp on the bench
