sanity check: Slack at the top of pedal after Sachs 2.5 install
Old Dec 16, 2014 | 11:33 AM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
Originally Posted by jjurroz
I've bled 3 times now and same issue. I'm beginning to think it's the slave now. I tested the accumulator and I'm fairly certain its working fine. I also checked under the dash by the pedal for leaks at the master and everything is dry. All signs point to slave at this point.
-Jose
Yes it is likely that one of your components are failing. From what i understand, the accumulator fails usually before the slave gives out. When i had the leaking pentosin reservoir up front with the slightly hard to depress pedal in the morning, i took it to the shop and they confirmed the slave and accumulator needed changing. I went ahead and changed the master cylinder as well as it was only 1/3rd the cost of the slave.
Old Dec 17, 2014 | 04:29 PM
jjurroz's Avatar
jjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant future
So before going down the route of changing parts I went ahead and double checked everything to make sure nothing was leaking. I looked under the car at the coupling between slave and engine reservoir and found that it was leaking again. This is most likely where it's losing pressure causing the pedal to drop.
The o-ring that was used was not an oem o-ring and my guess is that the pentosin is causing this o-ring to fail.
Does anyone know what the part number is for the o-ring that goes inside that coupling?
-Jose
Inspected everything again and found a leak at the coupling. There's a small oring inside there so it was replaced. Re-bled the system and the pedal was perfect. Drove it around for 10 miles or so and everything was fine. Wake up this morning and the pedal is stuck at the bottom again!
At this point I'm not sure what it could be.
Thoughts?
Old Dec 29, 2014 | 07:32 PM
jjurroz's Avatar
So finally some resolution to this saga. I went ahead and used a power bleeder (motiv) using the instructions from porsche and that took care of the problem. It seems manually bleeding these cars is a ***** and requires a ****load of time so definitely the motiv bleeder is a godsend for clutch bleed as well. Some people had issues with reusing their motiv but the fact is that pentosin is water soluble so washing it off with water, soap and then alcohol removes all traces. I guess if you're that paranoid you can buy another one just for the clutch. They're relatively cheap for the hassle and time they save.
Thanks everyone for their input!
The moral of this is to always diagnose and not just replace parts on a whim.
-Jose
Old Dec 29, 2014 | 07:51 PM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Glad you found the solution!
-Mitch
Old Dec 29, 2014 | 08:33 PM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Good to hear you got it sorted out. How does it feel now? Mine feels exactly like stock with regards to the pedal pressure and all. The actual engagement is slightly more abrupt, but I could very easily put somebody in the car that has never driven it before and they would never know it wasn't the factory clutch. Incredibly pleased with the drivability of it.
Old Dec 29, 2014 | 08:37 PM
jjurroz's Avatar
I'm ready to roll Mitch! You ready???
-Jose
-Mitch
Old Dec 29, 2014 | 08:39 PM
jjurroz's Avatar
I'd venture to say that it feels 'better' than stock. Car feels faster and smoother. I don't get the usual bog in reverse either now.
Old Dec 29, 2014 | 08:41 PM
A418t81's Avatar
Excellent. I was expecting some hit to drivability as usually happens with any clutch upgrade, but this one really is like having your cake and eating it too. Really no downsides at all.
Old Dec 29, 2014 | 08:48 PM
-Jose
Haha I am always ready!
-Mitch
awdbiturbo1
Feb 18, 2016 10:24 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
magoochi
Aug 23, 2015 05:54 PM
MagicRat
Aug 22, 2015 12:37 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
