Sponsored by: Bears Transport
Definitive Guide to Pinning Coolant Pipes
Old 02-23-2015, 06:07 PM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
I would guess with parts and labor probably high 5's.
Old 02-23-2015, 08:02 PM
nuclearfishin's Avatar
nuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the rough
That's pretty close, I paid a little over $6k but I had a bunch of other things done while the engine was out(i.e. new plugs, coils, reservoir, etc.).
Old 02-23-2015, 08:26 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
I'm looking at $4,424.90 for the Pipes alone.
Old 02-24-2015, 03:22 AM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
That's ridiculous. 10 hrs to drop engine and 16 to pin should be enough. What are the labour rates like around you?
Edit: now going through this with an OPC, and they're spending way more time on it than originally estimating. I'm officially eating my own words
Old 06-14-2015, 08:14 PM
nzskater's Avatar
My engine is out to sort what I have since discovered is all three plastic elbows leaking to a certain degree, along with the pinning of the metal pipes.
I've read endlessly on the pipes needing to be sorted, and seen reference of there being 7 metal pipes (plus the three plastic elbows) that need fastening by either pinning or welding, but I can't find the seventh pipe. Can someone kindly point it out to me?
Plastic elbows:
Three plastic elbows to be replaced with Sharkwerks alternatives
Smaller casing:
Three pipes off the smaller casing near the turbo water pump
Larger casing:
Three pipes off the casing near the main water pump
Old 06-15-2015, 08:58 AM
roncooper's Avatar
roncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond repute
5k wow how much is it just for the parts? I'll drop the engine and weld them myself.
Old 06-15-2015, 11:30 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
$300 for elbows to replace the rubber is the whole cost if you DIY it....
http://sharkwerks.com/porsche/techni...urbo-cars.html
Old 06-16-2015, 12:22 PM
nzskater's Avatar
Does anyone have any info on the 7th pipe that needs pinning? Have poured over the Sharkwerks site and all the forum posts, and can still only find 6.
Old 06-16-2015, 11:45 PM
elite1's Avatar
I had 7 welded. Sorry for the bad photos but, hopefully they help.
Old 06-17-2015, 03:11 AM
nzskater's Avatar
Thanks, that helped. I think the one I was unsure about is in your second photo. It's on the right side, to right and below the oil filter. It can be pinned while installed.
Old 06-17-2015, 10:40 PM
elite1's Avatar
Perfect!
I guess you are pinning the fittings. What lead you to this decision over welding? I know many do this but, just trying to understand why.
I guess the real question would be, Has anyone had an issue with your welded and pinned / tested conversion?
Btw, I was starting to think that I needed to ship my car to New Zealand for oil changes on your prior comment about the labor!
Old 07-06-2015, 10:20 AM
roncooper's Avatar
300? From what I see on their website it's more like 490.00
Old 07-06-2015, 11:15 AM
93ls1rx7's Avatar
Sorry, you are correct. I was looking at the GT3 page that is linked off the article on pinning
Old 07-31-2015, 12:54 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Mitch did you ever do your pinning?
Old 02-11-2019, 08:07 PM
turb0's Avatar
turb0 is an unknown quantity at this point
I'm about to embark on this task (welding the coolant pipes and replacing the elbows), so what other vital/efficient things that should be performed while the engine is out?
Quick Reply: Definitive Guide to Pinning Coolant Pipes
