997.1 Turbo Manual Tranny and Diff oil change question
Old Apr 20, 2015 | 06:49 AM
Cubes's Avatar
Cubes is a splendid one to beholdCubes is a splendid one to beholdCubes is a splendid one to beholdCubes is a splendid one to beholdCubes is a splendid one to beholdCubes is a splendid one to beholdCubes is a splendid one to beholdCubes is a splendid one to behold
Hi guys,
Those of you who have done this work yourself, did your drain plugs (or fill plugs) have the aluminum crush washers from the factory? I have done this work before in a number of vehicles (non Porsche) and always replaced the original washers with new ones.
This Saturday I decided to replace all those fluids including the controller box and NONE of the plugs had washers installed. In fact the shape of every plug was tapered....as if it was designed to NOT have a washer at all.
I went ahead and installed the washers anyway just in case someone had messed that up, though I find that hard to believe as everything appear as if it had not been touched from the factory.
Thoughts?
Old Apr 20, 2015 | 11:06 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
I believe the cars left the factory without the crush washers but I add them, so i'd say you're good.
Old Apr 20, 2015 | 11:50 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Old Apr 20, 2015 | 12:26 PM
Thered300zx's Avatar
Thered300zx is infamous around these parts
Just did mine two weeks ago. Was also under the impression crush washers were needed. When I went to remove plugs, I also found that they were "tapered" and had no washers installed. I reinstalled without washers, and no issues yet.
Old Apr 20, 2015 | 12:57 PM
Cubes's Avatar
Originally Posted by turboslut
Thanks. I saw that DIY. It indicates the "replacement" of the washers but I had nothing to replace to begin with. Same as "Thered300zx" also discovered during his.
Old Apr 20, 2015 | 06:06 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Will Mobil fluid be better than factory?
Old Apr 20, 2015 | 07:58 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Have to be very careful changing up the fluids....especially on the transmissions. If you create any differences in viscosity or other variables you will have all sorts of issues with clutches slipping and/or incorrect valve pressure...Just FYI.
Not saying you cannot use a Mobil 1 product, but make sure whatever you use has exact specs.
DC
Old Apr 20, 2015 | 09:20 PM
au2bahn's Avatar
Originally Posted by therock88
Have to be very careful changing up the fluids....especially on the transmissions. If you create any differences in viscosity or other variables you will have all sorts of issues with clutches slipping and/or incorrect valve pressure...Just FYI. Not saying you cannot use a Mobil 1 product, but make sure whatever you use has exact specs. DC
Good to know. Thanks
Old Apr 21, 2015 | 12:48 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
We have a great amount of DIY tech articles that can help with any future DIY work that you made need help with. It's interesting about the crush washers. I may have a tech look into writing an article about this exact thing. Thanks for the info!
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
COBB Tuning
Jan 1, 2025 09:02 AM
SharkyShark20
Sep 19, 2015 09:54 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
