Urgent leaking
Old Apr 25, 2015 | 08:51 PM
Slider's Avatar
OK, you need to identify the fluid - Color? (Red, Green, Other). Smell - (Hydraulic, sweet) Your new slave should be using brake fluid - not Pentosin - so if it's not green and doesn't smell sweet, it could be clutch fluid (but there should be none of that on the left side rear of the car).
Have you been able to follow the drip up from the ground, onto the engine and to a source?
Old Apr 25, 2015 | 11:09 PM
jaygotti's Avatar
jaygotti is infamous around these parts
Can't seem to find the source but the it is green fluid
Old Apr 25, 2015 | 11:23 PM
Slider's Avatar
OK, that's Pentosin. It may have come from the hydraulic lines removed from the old clutch. Check both ends to see if the lines have any fluid remaining. Clean up any fluid you can see. Your slave is OK because it doesn't contain Pentosin any more so it didn't come from there.
I would top up and monitor your steering fluid level and see if any more fluid appears on the floor, but I would bet the fluid moved in the disconnected lines and just emptied on the floor.
Old Apr 26, 2015 | 12:11 AM
jaygotti's Avatar
Why would the clutch pedal act like Tht then? Before it was fine, but the shop forgot to add the safety pin on the pedal so I put it in. After I did it started acting funny... I didnt move anything or break anything just put the pin in.
Old Apr 26, 2015 | 12:41 AM
Slider's Avatar
OK, you may have two issues, but lets get the fluid one first. Did the shop put Pentosin in your new GT2 clutch system? (That would account for both)
Old Apr 26, 2015 | 05:37 AM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
I bet its the O ring that's on the pentosin reservoir. When I was working on a coolant leak, I had to loosen the pump. That is where I saw a small leak. I replaced the O ring as part of the maintenance.
Old Apr 26, 2015 | 08:25 AM
jaygotti's Avatar
I would assume so. Would i damage anything driving on low pentosin?
Old Apr 26, 2015 | 08:30 AM
Slider's Avatar
It depends on how low. Top everything up and then check frequently after small trips at first so you can work up some confidence.
Old Apr 26, 2015 | 12:30 PM
jaygotti's Avatar
Can you text me so I can send u a video of the clutch pedal, If u don't mind. 347 920 6 three 5 three
Old Apr 26, 2015 | 02:02 PM
Slider's Avatar
Text sent - but you could post your video here for more input too.
awesomebang
Jul 5, 2017 08:48 PM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
