Sponsored by: Bears Transport
New Project 4.0L 1200HP
Old 05-17-2015, 07:05 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Originally Posted by ysfg35
Nobody said pauter rods are bad , am running them since 2 years with zero issue , 2.0bar all the time with hta3586 turbos .. Never failure .. But I do not want to take a risk damaging the engine if the rods got bent !
I guess my point is the Carrillo and Pauter rods are pretty much canned rods for these engines. With all the money you are spending why not have a rod designed specifically for your hp/torque/rpm's. This way you get the lightest rod
capable of handling your specific motor.
Old 05-18-2015, 01:02 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
You read my mind chad , that's what I did
I went with ESmotor/carillo custom Rods that suppose to
Hold 1900hp !
I will share a pics very soon
Old 05-18-2015, 02:34 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Originally Posted by OS Inspector
who has bent Pauter rods from horsepower and not detonation id be curious to see.
Hello,
Not bent but i have seen small end problems.
Small end material gets worn and makes thicking noise because of the increased clearance between piston pin and small end.
ESMOTOR
Home of the Worlds quickest Porsches
1/4 mile: 7,95 @ 190 mph
100-200km/h: 2.16 sec
200-300km/h: 3.43 sec
60-130mph: 2.52 sec
100-150mph: 2.19 sec
Email: emre@esmotor.com.tr
Web: http://www.esmotor.com.tr
Instagram: http://www.instagram.com/esmotor
Old 05-18-2015, 09:29 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Originally Posted by Emre@Esmotor
Hello,
Thank you, now that i can believe. one last question what power level / mileage did this occur at?
were they stock length or extended length / with larger bore?
Old 05-18-2015, 09:33 AM
Happened 3-4 years ago when my car was 3.8 liter with GTX3076 turbos.
Stock length rods with stock crankshaft. Mileage was about 5000 miles.
Max rpm was 7500 and max boost was 1.95bar (around 29psi)
I wasn't driving with this boost all the time though. Daily boost was around 20psi.
ESMOTOR
60-130mph: 2.52 sec
Old 05-18-2015, 09:40 AM
good info thx
Old 05-26-2015, 06:29 AM
ysfg35's Avatar
Engine is leaving tomorrow to ESmotor
https://imageshack.com/i/eydAYvtdj
More pics soon
Old 07-26-2015, 06:50 AM
ysfg35's Avatar
A little update ..
Engine is almost ready
GT3 heads look perfect , I will try to post some pics today
Can not wait to run it and Emre visit Kuwait to tune syvecs ECU !!
Old 07-26-2015, 10:11 AM
Brooklyn boosting's Avatar
Brooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond repute
This will be the route I go in the future ... What are the milage these motors are expected to last with high maintnance and lower boost for street and turning up the wick for some track events...
Old 07-26-2015, 10:16 AM
ysfg35's Avatar
From my exp building many 997TT , 996TT plus mine , if you do the engine build very right , change the oil in time .. Run the boost based on the octane in the tank .. It will live years and years ,
Old 07-26-2015, 10:21 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Question. If the rods are equally strong, does 32g of weight really matter for an engine that is putting out over 1000hp? How many roads are there? I understand rolling weight for wheels and overall weight but 32g x how many rods is probably a pound total?
Old 07-26-2015, 12:30 PM
SamboTT@ByDesign's Avatar
Super exciting!
Old 07-26-2015, 12:35 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
Good luck with the build
Old 07-27-2015, 09:45 AM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
I noticed the small end of the rod on the stock motor is fairly narrow. Is the solution to the small end wearing to go with a water small end, and matching piston?
Hoping to keep stock pistons on my build.
Old 09-14-2015, 06:23 AM
ysfg35's Avatar
Little update :
Engine is ready since 3 weeks , am just waiting EMRE to ship it (customs etc etc etc from my side late )
!!! am so exciting to test it (2.5bar) and get the great features in Syvecs ECU
If any one consider to build an 1000-1500hp engine , talk to ESMOTOR , they even give a warranty for their work !!! I received pics for the build from the start to the end which am sure I was in safe hand !!
Quick Reply: New Project 4.0L 1200HP
