997.1tt crankshaft pulley tuning
You guys hit on it, the issue is easier for porsche to keep replacing engines for those customers. Also gotta keep in mind, very few 4.0RS are driven...
All crankshafts have torsional harmonics, the issue is when there is very little to dampen it out. The dual mass flywheel does an OK job, but it's on the wrong side of the crank shaft to be more effective. It's better than nothing. 997.2 GT3's for example, don't have issues with variocam actuator bolts backing out. 997.2RS does, difference, the GT3 has a dual mass flywheel, the RS has a single mass flywheel.
If you don't want the dampener, completely understood, but keep your dual mass flywheel at least...
You are right, however, inline 6s should be very similar but all the new inline 6 forced induction BMW motors 2006+ come from the factory with harmonic balancers at the crank and as I've mentioned earlier there have been attempts at running solid one piece pulleys of which all reported/documented cases had motor failures directly related to the crank pulley. Everything I've read on the research and data gathering by Jamie and the people he worked with simply tells me it is a worthwhile investment to run ATI's harmonic balancer. We'll run it on our shop car's motor when the ERP and its single mass flywheel make it back in the car. I don't see any significant performance advantages out of a solid lightweight crank pulley and would much rather focus elsewhere for power/response gains.
i'd give it a shot but to be honest i think $1000+ for a balancer pulley is a rip-off.
#TeamAIM
#TeamAIM
if BMWs came with a harmonic damper from the factory and people replaced it with a regular pulley, that sounds like a mistake to me. the M96 and M97 engines do not come with one from the factory which is why a lot of guys are having success running the GT3RS pulley and the EvoMS pulley.
My 2c, having a properly tuned balancer on the crank is something I'd personally choose for my motor any day over using a solid single piece for peace of mind and get my gains elsewhere.
There are many reasons why things get priced one way or another and a lot of it has to do with volume to make it worth making for a manufacturer. The same can be said for many other custom parts on higher end cars. Making 10 of something and 10,000 can change costs dramatically. ATI dampers for some other motors such as small black Chevys go for 350, sold by Jegs, but you can imagine the volumes being much different.
everyone is all about cost cutting. if the BMW you refer to did not need a harmonic balancer, BMW would not have put it on the car. going back to my point that if a car came with one, removing it is a mistake.
#TeamAIM
#TeamAIM
However, in this case the issues Jamie is describing are different.
Funny enough, check out this story on M96/M97 dual mass flywheel removal. I know its on the extreme side of things but you mentioned them, not me
http://flat6innovations.com/index.php/broken-crank
Anyways, I've got my ATI damper on the way.
Balance and Harmonics are not the same. Really wish they weren't called harmonic balancers as it's confusing... And whomever called my word usage out, thanks for that...
Harmonics are the vibrations resulting from the uneven pulses from the firing of each cylinder. If you tap a bell at a regular interval it gets louder and louder. This is what is happening to your crankshaft, it's ringing, like a bell, at a certain point, the ringing has a significant amplitude and something has to give (like bolts backing out, oil pump gears breaking etc...). The ringing is in the torsional direction (in the direction of rotation), so it effects many things. Bolts coming loose, is one, but it also effects the valve train timing as the chain connecting the cams to the crankshaft is getting pulled back and forth, this causes valve timing changes and reduces horsepower.
What the damper is doing providing some counter force to the crank shafts harmonic oscillations and acting to dampen the oscillations before they grow in amplitude.
Crankshaft Balance is the balance in the rotating mass, so that it's not "lopsided"...
And an ERP clutch would be a single mass
Don't compare the flat 6 to an inline 6, not the same animal at all when it comes to balance/weight distro etc.
Zero issues here running a 3.8 turbo Mezger with OEM LWFW and 996Cup light weight underdrive pulley. I am running an RSR crankshaft. Engine has 70+ track hours on it since last rebuild and is revved to 7500 pretty much on each shift.
