Clutch acting weird
Old Jun 13, 2015 | 08:03 PM
jaygotti's Avatar
jaygotti is infamous around these parts
Clutch acting weird
I recently got a Sachs 2.5 Clutch with the gt2 conversion, had it in for a month or so and a few days ago the clutch felt weird. It releases all the way up but when I go to press it there's pressure only 75% of the way. When the car is warmed up its back to 100% pressure. I only noticed this when I park on a hill, when I park on strait surface this doesn't happen. What could it be? Also there are no leaks and clutch fluid is fine.
Old Jun 14, 2015 | 09:19 AM
Macster's Avatar
Sort of reads like a clutch fluid problem.
In cases like your's I advise a proper clutch fluid (and brake fluid if the systems share fluid) flush/bleed be done before anything else to eliminate possibly contaminated fluid being at the root of the symptom.
Old Jun 14, 2015 | 03:54 PM
jaygotti's Avatar
Originally Posted by Macster
Sort of reads like a clutch fluid problem. In cases like your's I advise a proper clutch fluid (and brake fluid if the systems share fluid) flush/bleed be done before anything else to eliminate possibly contaminated fluid being at the root of the symptom.
I hope, but why would it all of sudden do it if it was working fine before?
Old Jun 19, 2015 | 06:29 PM
Sayajin's Avatar
Sayajin is just really niceSayajin is just really niceSayajin is just really niceSayajin is just really nice
Its possible air got into the system over time. I agree with a bleed first and foremost. Its the easiest and cheapest thing to check!
-Sayajin
Old Jun 19, 2015 | 07:05 PM
jaygotti's Avatar
Originally Posted by Sayajin
Its possible air got into the system over time. I agree with a bleed first and foremost. Its the easiest and cheapest thing to check! -Sayajin
Got it bled so far so good. Thanks guys
Old Jun 20, 2015 | 06:41 PM
jaygotti's Avatar
Let the car sit from driving it this morning, got air in the pedal AGAIN! Wtf? How can air be getting into the system?
phils996
Nov 8, 2018 04:44 AM
Ellipsis
Mar 28, 2016 03:28 PM
Yogi911
Sep 9, 2015 08:20 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
