Track Day with the 997.2 Turbo S
Old Jun 15, 2015 | 11:01 PM
longboarder's Avatar
This is a long vid (20 min) of my afternoon track session this past Sunday at Auto Club Speedway. Laps 1 and 2 are just warm up to get the tires heated up (fast forward to the 5 minute mark unless you are just bored lol). I had to run -10 psi to start in order to end at 36F/44R. I'm in the Open Passing Run Group.
The thing is...this car is downright scary in the corners so I'm going really really slow. I'm sure with stock power I would be much more comfortable and sadly probably faster. But with 30 pounds of boost in the mid-range I have to be sooo throttle sensitive that if I give even slightly too much throttle in the corners I'm in for a scary ride. On snap oversteer I can "catch" my M3...can't do it in this car.
So I'm pretty much not even accelerating in the corners. Just cruising through them and then unleashing fury only when the car is pointed completely straight.
This car needs a pro driver. But for now it's got me.
Old Jun 16, 2015 | 01:33 AM
mike810's Avatar
mike810 is infamous around these parts
Awesome, I need to check this place out one day. I live like 15 minutes away lol.
Old Jun 16, 2015 | 02:00 AM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Looked fun! Your car on the straights make those cars look like they were just out for a Sunday drive .
Old Jun 16, 2015 | 07:45 AM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
Thanks for sharing the great vid Adam. Did you try switching the tune back to stock?
Old Jun 16, 2015 | 11:40 AM
NephroC4S's Avatar
NephroC4S is infamous around these parts
Great vid! Curious about how fast you got up to on the main straight. You were flying! Thanks for sharing.
Old Jun 16, 2015 | 12:19 PM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Cool video. your hot tire pressures are high in the rear. You should target 34/36 both front/rear.
Old Jun 16, 2015 | 12:34 PM
Of course you should!!!!!
Good question. My current tune only has a Pump and Race mode. Boost profile is the same for both tunes but Pump runs less timing. Although with the 100% meth I'm running a little more timing then if I was just straight pump 91 octane gas.
I didn't even turn my vBox on so I don't know for sure but looking at the speedo on the first two laps maybe 150mph on the straight and the long turn at 115mph but then as the tires got more pressure I was maxing out at 170mph before I hit the brakes to enter the long curve and took the turn at 120-125mph. I'm convinced a better driver could have taken the curve at 145+.
Interesting. Since I have stock tire size I was going off the F/R tire pressure recommendation in the door sticker. I asked a few of the Porsche guys and that's what they were doing as well...although they were GT3's so their door pressure stickers were different than mine. Where are you seeing that 36R hot is better than 44? Thx.
Old Jun 16, 2015 | 01:54 PM
eurotom's Avatar
The door sticker refers to the recommended pressure for street driving with a fully loaded car, meaning passengers luggage etc. For normal use or Partial load 33/39 on is what is recommended by Porsche.
36 target for hot temps is not in any manual rather my personal experience and many others who track their cars. For me anything above 36 hot gets greasy.
Old Jun 16, 2015 | 02:12 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Agreed! I have found 32 front/35 rear hot to work best at the track with PS2's, RE-11's and R888's on my 997.1. Start at ~26f ~29r, give them a couple of laps to warm, then bleed down after each session. You'll be amazed how much better they stick. A 10 psi gain is pretty typical. Anything over 40 psi gets very greasy and the tires really need to cool overnight in order to recover. This season I'm going to run the Sport Cup 2's at similar pressures but will go with a nitrogen fill to avoid most of the intraday adjustments, I hope.
If you're driving on them back home, fill them to 45-50 psi before leaving the track and the tpms idiot lights will reset after driving for awhile. Then reset pressures for street use next morning after the tires have cooled and temps stabilized. Hope that helps.
Old Jun 16, 2015 | 05:41 PM
MONKY LONDON's Avatar
MONKY LONDON is infamous around these partsMONKY LONDON is infamous around these parts
Question
So 32/35 thereabouts hot and we should be good? I'm about to take my 911 on track, running Cup Sport 2.
When in sport mode, how much bias does the 4wd give to rear, I read 80%? See if I can do some skids
Thanks for sharing OP, I liked your video. Car goes very well indeed, how much power you running circa?
Old Jun 16, 2015 | 06:03 PM
Ok got it thanks. This is probably why cornering was so difficult for me. The combination of slippery rear tires and a scary turbo spool was tough to manage.
Excellent thanks I'll def start a bit lower in both the F and R.
Old Jun 16, 2015 | 06:10 PM
Maybe around 700 HP and 750 TQ on pump gas plus methanol.
This car is quite fun at the track you will love it!
Old Jun 16, 2015 | 10:57 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Nice runs Longborder. You lines got better with every lap.
I think you now have a new challenge vrs. the 1/4 mi competitions you have accomplished. Think of all the chair time you got running your car here vrs, 1/4 mi events.
The track I run at doesn't have the straight's you do so, I could never use 700HP at it. 600HP crank seems to be plenty.
Suspension and driving patience's will be on you list soon.
Old Jun 17, 2015 | 01:16 PM
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
Great video as always bro. Looks like a bunch of fun. I'd be worried about smoking my brakes though, so I'll live through your youtube channel
Old Jun 17, 2015 | 02:09 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Looks like you're having fun with it at least! I'm sure with more track days under your belt with this car you'll get more comfortable with its power. You seem to handle it well nonetheless. Been to auto club a few times, but have yet to make it on the track. Doing some speed ventures stuff soon as well! Maybe I'll see you out there sometime.
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
