Turbo upgrade
Old Jul 4, 2016 | 04:57 PM
  #46
Obb's Avatar
Obb
Obb has a spectacular aura aboutObb has a spectacular aura about
Originally Posted by K24F
Little logging alone tonight, same flat road, vbox showed 4,3'/4,9'/7,9' at 100-200/60-130/100-250, pretty fast!
1,46Bar-19°C
Still a bit too rich
No graph or log of this? Its fast for that boost but come on people post some graphs and logs otherwise anyone can claim anything on here. If you don't want to that's fine but I really enjoy that sort of stuff and I'm sure many others would as well.
Old Jul 4, 2016 | 07:26 PM
  #47
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Tried a litlle more boost before 4500 to help the spool tonight, did 100-200 in 4.7' 2 persons in during the logs.
The long terms are still a bit low while all is ok with Lambdas and ignition angle stability, Todd will see that. (Btw, IDC is 60%)
The feeling is better, more torque.
I guess alone in the car by 1,6Bar and lower AT the car can touch/break the 4' at 100-200, I won't run massive boost.
Are you using Cobb to tune your car !?
As I thought you need special map sensors to read above 1.55bar !! Not sure if there are other Tuning softwares can see above 1.55bar maps !??
Congrats .. 4.7 sec with VTGs build is perfect
Old Jul 5, 2016 | 07:30 AM
  #48
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Xona 5756 ... Built engine ...
O 3eedk imbark ...
Old Jul 5, 2016 | 03:04 PM
  #49
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
You are right, it is just times I read on the Vbox when logging, I have not the card in.
Right as well fast for that boost, the EVC showed 1,46Bar but the logs show more about 1,48-50Bar.
I will do dedicated runs when the tune ok and send the vbox file.
Old Jul 5, 2016 | 03:37 PM
  #50
K24F's Avatar
My vtgs are far from years my friend!
I run the stock ECU tuned by Protomotive, we are still in the boost level the oem sensor can read (1,55Bar maxi) for now.
Anyway the ECU does not control the boost anymore since the non vtg turbos,
the boost can be or not in the blind area of the sensor the ECU controls the same way the ignition and fueling.
Nevertheless I plan to bolt a GT2RS sensor or equivalent and recal the ECU to match with it, in order to be still able to check the boost curve mapped with the EVC6 even when 1,55 Bar are reached.
(I plan to run about 1,6Bar maxi, the goal is reliability not breaking records)
Old Jul 9, 2016 | 04:34 PM
  #51
K24F's Avatar
A little pic, ok it was a dedicated run this time, flat road, 20°C, 1,5Bar
Old Jul 9, 2016 | 04:42 PM
  #52
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Nice 4.3 congrats bro
Old Sep 25, 2016 | 04:09 PM
  #53
K24F's Avatar
Hi All, many occupations took me not so close my car/built for more than 1 year, I'm glad it gets smoother now.
So after several tunes Todd told me "this last one is ok".
I didn't had much time yet to test the car but already (dramatically) killed a friend's F12 and ran a few Vbox times.
By 20°C AT did 4,2' and 7,7' at 100-200 and 250, one 96-209 showed 4,8'.
The boost is set at 1,55bar, just at the stock sensor blindness limit, the EVC6 shows peaks at 1,58Bar and IDC is about 65%.
The car is very fast and strong, I "guesstimate" power about 850 to 900hp.
I have vbox pics but I will retest with the card in order to send the result and perhap's calculate the power.
I won't raise the boost for now as I do not participate at events, only my pleasure, a few track days and a few friendly rolling "races" on desert clean roads. (Next is with a >1000hp GTR...)
Stay tuned!
P.
Old Sep 25, 2016 | 11:19 PM
  #54
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Congrats bro very impressive for just 1.55 bar
did you shift?
Ali
Old Sep 26, 2016 | 05:47 AM
  #55
K24F's Avatar
did you shift?
Ali
Thank you Ali, no shifting from 100 to 200 (4rth) cause was datalogging, 100-250 is 4+5th gear, I will test if a gain with 3+4+5.
Old Sep 26, 2016 | 11:15 AM
  #56
GTRNICK's Avatar
Well done P your car is flying!!!!
Old Sep 26, 2016 | 12:48 PM
  #57
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
Any 200-300 runs?
Old Sep 26, 2016 | 02:13 PM
  #58
K24F's Avatar
Yes it becomes truly fast Nick!
Thunder, I admit I didn't dare yet to pull longer... I might getting old! J
Old Sep 26, 2016 | 04:41 PM
  #59
GTRNICK's Avatar
Well you have given me something to look forward to now
Old Sep 27, 2016 | 03:40 AM
  #60
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
That's pretty quick. Congratulations
