New problem with my ohterwise very reliable 997
4+ years of near trouble free ownership of my 2007 997.1! Friday the car developed an issue under hard acceleration. Everything is perfect and normal up to 4k RPM, then I get a distinct shutter/stumble (three shutters to be exact) then it continues on, but will much less torque. It's very consistent/repeatable.
Instinct says secondary injectors are out, but I want to get opinions from the board. The car has tune/exhaust/semisolid mounts/sachs 2.5/TPC suspension module and some other supporting mods. Tune/exhaust have been on for 8k miles and 2.5 years without issue. The plugs and all injectors were replaced at the time of tune.
Let's hear some ideas
. Nearest dealer is 3hours away and nearest mechanic 2:20. I'd like to have some idea ahead of time. Thanks!!
What's a secondary injector on a 997.1?
Plugs or bad O2?
Plugs or bad O2?
Have you logged the car? That would be the first step. Send the log to your tuner they should be able to provide insight.
Sounds like missfires but without logs and codes from the ecu it's a guessing game.
If you have a canned ots tune and no means of logging get a durametric cable. Or a Cobb accesport.
Would the plugs or O2 sensor be such a reliable shutter at 4K rpm? Below 4K everything is completely normal, like nothing is wrong. I do not have a Cobb access but will look into getting one now
That is what my guess would be.
DC
I'll find out what plugs EVOMS recommends and order. Will replace O2 as well. If that doesn't worked, then make the long drive...
Assume we will find out if/when he reports back his findings.
DC
If its an actuator rod issue it will be low on boost. Is it?
If not then it will usually be the plugs/coils and it will feel like you are hitting your limiter earlier in the rev range.
Hope you get it sorted.
Finnegan
Oct 16, 2015 08:20 PM
gsieck
Oct 11, 2015 11:49 PM
