Another look at the G1 Coolant repair
Old Feb 16, 2016 | 07:41 AM
jimmyrepasi's Avatar
jimmyrepasi is a splendid one to beholdjimmyrepasi is a splendid one to beholdjimmyrepasi is a splendid one to beholdjimmyrepasi is a splendid one to beholdjimmyrepasi is a splendid one to beholdjimmyrepasi is a splendid one to behold
Started by removing the engine
Then after removing all the accessories and intake manifold parts you can remove the oil cooler manifold. It bolts directly to the top of the engine and has plastic coolant pipes underneath it that fail
The failed pipe on this specific 997 turbo
Photo of the shoulded that broke on the failed pipe
Side by side of the original plastic pipes and the Sharkwerks Stainless Steel replacements
All three installed on the oil cooler manifold
Due to the mileage and nature of the use for this car the client had decided to replace all hoses and clamps as well as "pin" all the aluminum coolant pipes
There wasn't much information on this 7th pipe. I don't believe the 996 generation of this engine has it. It is located behind the power steering reservoir and a/c compressor
I consider this preventative maintenance. From what I've experienced the plastic pipes or the aluminum pipes loosening is an inevitable failure. Usually between 40k-50k miles depending on climate and use.
Feel free to contact me directly with any questions or comments or price quotes. I am located at a Premier Porsche Workshop in Connecticut
e8_pack
May 17, 2016 10:43 AM
997ttc
Feb 4, 2016 08:45 PM
xbox_fan
Jan 27, 2016 10:08 PM
