SRM EFR7163 Eliminator Kit breaks 1000whp!
Old Feb 24, 2016 | 08:56 AM
Originally Posted by dhahlen
Backpressure ratio was 1.3 on the mustang graph, no changes were made between that and the dynojet.
I turned the gates up and we hit 1.7 on backpressure and made no more power, so I dialed them back.
I wish my damn proefi was logging, but it got weird and didn't. I'll make sure it's logged on Friday.
Valvetrain is stock, I have a set of cams that need to go in, but they won't be in for another week. Also have Ferrea pieces to add to it. Head will not be ported, so I'm somewhat limited, but the plan isn't to exceed 35psi. If anything, I'd like to achieve the same power at 32psi with cams in place.
are you doing ferrea valves too?
#TeamAIM
Old Feb 24, 2016 | 10:45 AM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
Yes, but since I'm on stock head, I don't plan on doing anything over 7800. Turbo heads tend to have issues at 8k and above. Cost for porting is a lot, so I may end up doing a GT3 head swap sometime down the line.
Old Feb 24, 2016 | 11:58 AM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
Congrats! Awesome car....
Old Feb 24, 2016 | 12:00 PM
dhahlen's Avatar
Has a bit of your build in it now. Trans goes in tomorrow
Old Mar 7, 2016 | 08:00 PM
somefoo1's Avatar
somefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of light
Old Mar 7, 2016 | 08:31 PM
dhahlen's Avatar
Originally Posted by somefoo1
Haha, they were available earlier, someone snatched them up.. maybe from this post?
GT3 cup heads don't have secondary air passages like the turbos, not that it matters since I have eliminated mine. Would need to source cams and all the other stuff. I am considering a GT3 head, but for what I'm after, the turbo head will probably be fine with some upgrades.
If someone had GT3 head, with cams, springs, etc ready to go for the right price.. I'd be hard pressed to pass it up.
Old Mar 7, 2016 | 08:47 PM
somefoo1's Avatar
literally they were for sale when i posted that.
Had i owned a 911 right now i would have been the one to snag it but i'm still trying to decide if i want to go with a 996 on the lower end of the quality scale (not dissing 996s but saying get one with questionable records) and build the crap out of it or get a 997 that's been well taken care of doing a chip exhaust and intercoolers and calling it a day.
Old Mar 8, 2016 | 08:31 AM
dhahlen's Avatar
No such thing.
I prefer the 997 over the 996 for a number of reasons, price not being amongst them, though.
Old Mar 8, 2016 | 08:40 AM
somefoo1's Avatar
Oh i completely agree. Nearly everything is better but having a spare 30k for engine work and turbos... that's the difference.
And yes... i had a big turbo subaru so i'm familiar with the boost addiction.
1. do what i mentioned above.
2. turbo failure.
3. bigger turbos.
4. worry about engine until you build it.
5. now that engine is built i can run bigger turbos.
6. boost threshold is a little high now, i either need more rpm or displacement
7. cams/head work.
8. bigger turbos.
9. stroker.
10.... bigger turbos?
Old Mar 11, 2016 | 02:13 PM
dhahlen's Avatar
Don't forget the transmission!
Old Mar 11, 2016 | 03:19 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Looks good
Hope you fix your boost leak soon
Best of luck buddy
Old Mar 11, 2016 | 03:26 PM
dhahlen's Avatar
Originally Posted by ysfg35
Looks good
Best of luck buddy
I did redyno it, but didn't get the graphs as I had a hydraulic line burst.
It's all been fixed, but now it's down for headwork, cams, etc.
Last run it made was 1087hp/1044tq at 35psi.
That dip at the end was due to the wg pulling duty cycle as we had the boost threshold set to low and it was the ECU removing boost.
I should have it back on the dyno in 3-6 weekends, depending on the schedule with SRM, they have a few customers in front of me.
Old Mar 11, 2016 | 03:43 PM
ysfg35's Avatar
You will be in good hand
Will wait your next thread
Old Mar 11, 2016 | 06:22 PM
oldbooster's Avatar
oldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to all
What's the deal with a GT3 head on the 997.1 turbo bottom end? Are you direct swapping it on without any modification? I did not know that was possible. How are springs of an NA GT3 head holding up to high boost? Very strange that it would just be a swap, very surprised.
Old Mar 11, 2016 | 06:49 PM
dhahlen's Avatar
It's not a direct bolt-on, some modification is required, but it's common.
The problem with the factory stuff is it's not designed for revving much over 7400. I was shifting at 7800 myself, so a spring gave way.
The GT3 heads also flow much better than the turbo head.
You can swap in the ferrea stuff as well to beef it up for big power, which would be recommended. No reason to just slap a stock head on if you're after 1000+ hp and doing it anyway.
