SRM EFR7163 Eliminator Kit breaks 1000whp!
Old Mar 11, 2016 | 07:09 PM
  #31
AZ996TT's Avatar
AZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really nice
Well. Was hoping to see you run at Gila Bend! Amazing HP!
Old Mar 11, 2016 | 08:48 PM
  #32
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
I was hoping to be there Shooting for the CA event, if not, it'll be the fall!
Old Mar 11, 2016 | 10:13 PM
  #33
oldbooster's Avatar
oldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to alloldbooster is a name known to all
Wouldn't you then want the gt3 intake manifold as well and I assume this only makes sense if going with the same size bore as the GT3 then.
Old Mar 12, 2016 | 06:38 PM
  #34
somefoo1's Avatar
somefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of lightsomefoo1 is a glorious beacon of light
Originally Posted by dhahlen
Don't forget the transmission!
god i don't even want to know what tranny build prices are on this thing...
Old Mar 12, 2016 | 07:12 PM
  #35
32krazy!'s Avatar
6500$ to 20,000$
Old Mar 13, 2016 | 06:17 AM
  #36
somefoo1's Avatar
Originally Posted by 32krazy!
6500$ to 20,000$
That's not as bad as expected.
When is considered the time to build the 6 speed?
Vs tip?
I think I had 12,500 in the legacy gt trans between the sti trans swap and ppg gear set and that was to hold the power these things come with.
Old Mar 13, 2016 | 06:58 AM
  #37
32krazy!'s Avatar
Vs tip?
theres no answer to that. prodigy ran 1000 hp on a stock trans for yrs. others have blown the trans on the first pass. theres a lot of torque to be had on these motors. the mechanical fuse is the axles. its much cheaper to break an axle than a trans housing. upgrade the axles and the power goes to the next weakest link. remember the diff and trans share the same housing. break either and you could be looking at 8000$ for a new housing.
i have what would be considered a mild built trans for my 996turbo all upgraded 1-3 997gt2 gearing steel syncros and billet side plate. dhalen has a fully built radner trans with billet forks, straight cut gears etc. 3 times the cost of mine
Old Mar 13, 2016 | 09:17 PM
  #38
dhahlen's Avatar
My 997 stock trans was fine at 1000whp, but I was easy on it. I swapped it before it would became an issue, and maybe it never would have??
3k of my trans is the diff, which is a weak spot anyway. The rest is gears and billet shift forks. I have guards gears in mine, but Rader makes his own stuff now - supposedly better.
He'll be able to build the 997 gearboxes like he can with the 996, I hear, but not sure when.
I am happy with the setup, it has really long gears which make it ideal for hauling ***. I can do 60 in first
Old Mar 14, 2016 | 09:41 AM
  #39
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
So the built 996tt works perfect on your car?
Old Mar 14, 2016 | 11:59 AM
  #40
dhahlen's Avatar
Yes, works well.
There are a couple things that are different, such as a bracket for the 997 coolant lines which doesn't exist on the 996 trans. I've zip tied them temporarily, but will need to fab a more permanent solution.
Old Mar 14, 2016 | 04:03 PM
  #41
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Yes, works well.
Don't go through the hassle. I'll give you $500 + a good 997 trans and you won't have to fabricate anything!
Old Sep 1, 2016 | 07:06 PM
  #42
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Have you taken it back to the dyno yet after fixing your boost leak issue?
Very interested to see what these turbos can do.
Old Sep 1, 2016 | 07:30 PM
  #43
dhahlen's Avatar
Hopefully in the next week or two. Finishing motor assembly with new heads and cams, then back on for adjustments!
Old Sep 1, 2016 | 08:07 PM
  #44
Bobbyfali's Avatar
You animal!
I will be waiting with anticipation for your numbers!
Old Sep 18, 2016 | 10:21 AM
  #45
AriS4's Avatar
AriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond repute
any updates ? which cams are you doing ? (* do you know how much lift they have ? *)
