hi every one ,, im new here this my first time using 997 tt 2007 , i was using 997 2s 2009 pdk , my 997 tt Make a sound like ticking , and someone mentioned to me that this voice comes from this piece, and i have to replace this part , can any one of you tellme what the name of this piece and how much the price , and whether I can replace it myself ?!
Hello, I had the same annoying ticking sound, I replaced the part and if I am not mistaken it was approximately 700Dhs (190$) and it solved the problem, I added the part diagram showing the part # I replaced; Online it shows up as 200$ +/-, with a 10% discount its around 190$. Part #99711002973. Confirm with a mechanic/dealer before you buy it to ensure it is the source of your problem.. Goodluck
Reason: Updated Diagram
thank you , im sure the ticking comes from this part , i can hear it and i feel it when i hold it
aaaand this is my first post ever, but my 997 tt makes a ticking noise also, which is synchronous to the revs. sounds like a lifter but I don't think it is. can you describe your noise or post a clip of it?
Ive also got this ticking noise on my 997.1 TT, usually happens between 1500-2000rpm. Ive taken the car multiple times to the Porsche dealer and they can't find anything. Any help would be appreciated .
Is the noise from the purge valve speed or rpm related? I have a fairly loud ticking noise that I can hear while driving with window down and it's not rpm related but it does get faster with higher speed. It's loud enough to hear reflected off buildings and other cars. Car runs fine. Is this what others experienced?
