Persistent P2099 After Cat fuel trim system too rich bank 2 code
Old Feb 29, 2016 | 08:56 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
Hey gang,
looking for some input here.
2008
6 speed
58k miles
Umw tune, but otherwise engine is stock
fuel regulator line just checked, still connected, no obvious loose clamps, etc.
When cruising, no codes. When you dip into the throttle a bit (say at least 8 to 10 psi) for a full pull, this code pops up after you get off the gas. Car obstensibly runs fine.
In two weeks, I have plugs, coils, 02 sensors (pre and post cat) and inlet tubes planned. Hoping that might solve it, but not sure.
I'm concerned the cats are not performing as expected, but I'm wondering if there could be any other reasons for the code.
Any ideas would be helpful.
thanks.
Old Feb 29, 2016 | 08:58 AM
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
I have seen fuel trim codes from a bad o2 sensor. Could also be a bad cat though. Hope you get it figured out.
What exhaust are you running?
Old Feb 29, 2016 | 09:32 AM
Quadcammer's Avatar
Thanks. Stock exhaust.
Old Feb 29, 2016 | 02:27 PM
ecpChris's Avatar
Wouldn't be a bad time at all to throw an exhaust on there
Old Feb 29, 2016 | 05:10 PM
Quadcammer's Avatar
thanks for the offer, but I generally like the stealthy nature of the stock system. I will see how the car responds to the work done and will proceed from there I guess.
papigko
Sep 15, 2016 11:15 AM
sdanaher
Feb 1, 2016 01:12 PM
Bleen
Jan 30, 2016 11:56 PM
robertwroth
Jan 30, 2016 07:40 PM
