AZN Optics - LED and HID Lighting Solution
Old Mar 7, 2016 | 10:58 PM
AZN Optics's Avatar
AZN Optics is infamous around these parts
Hello! We here at AZNOptics specialize in euro spec vehicles with finicky canbus systems. We offer the latest in aftermarket lighting from LEDs to HIDs. All of our products can be found and purchased on our website www.aznoptics.com! Our units are CANBUS compatible so error free! Plug and Play solution.
AZN Optics are official distributors for Morimoto HID components. Morimoto are one of the top aftermarket HID conversion kits available.
Already have OEM Xenons? We have replacement Morimoto D1S and D2S bulbs as well so you can upgrade to pure white 5000K and sportier white with a slight bluish hue 6000K.
We also have 194 wedge LED bulbs featuring our latest V5 technology paired with COB diodes and constant current IC drives to help protect and extend the life of the unit:
Festoon LEDs can also be had in a range of sizes (31mm, 36mm, 38mm, 39mm, 41mm) also uses our constant current IC drive:
Not sure what you need? No problem. Just shoot us a PM or email us at aznoptics@gmail.com and we'll be more than happy to assist you. Forum special bulk package discounts can be had as well!
Here are some pics of our 194 wedge LEDs plugged into a 958:
Old Mar 8, 2016 | 06:12 AM
Dennis C's Avatar
Which LED bulbs do you recommend for 997.1 tail lights? I'd like to keep my stock tail lights, but replace the bulbs with LEDs.
Old Mar 8, 2016 | 03:45 PM
AZN Optics's Avatar
Rear signals use a set of 7507 bayonet LEDs and reverse lights use a set of 1156 bayonet LEDs. Bayonet LEDs retail $30/set and are canbus enabled so plug and play.
Old Mar 8, 2016 | 04:42 PM
Dennis C's Avatar
What about the other bulbs in the rear tail light assembly? Do you sell those too? Thanks.
Old Mar 8, 2016 | 05:23 PM
AZN Optics's Avatar
Brake lights should be 1157 bulbs. We have not tested these dual filaments on your 997.1, but you're covered under our guarantee that if they don't work, you'll get your money back.
Old Mar 8, 2016 | 05:45 PM
Dennis C's Avatar
Thank you. I may order some and give it a try.
Old Mar 9, 2016 | 08:16 AM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
Not sure what the advantage would be of using LED bulbs in the stock tail light housings. You will likely need to run resistors (perhaps for each bulb!) and get little to no change in the visual aspect. I personally wouldn't bother...
Old Mar 9, 2016 | 09:29 AM
Dennis C's Avatar
My thought was that they would light up faster than incandescent bulbs and that they would last longer. I consider those both to be good benefits, and I would get to keep my OE solid red tail lights. I much prefer them to the aftermarket LED units.
Old Mar 9, 2016 | 09:45 AM
AZN Optics's Avatar
Our LEDs are canbus enabled with built in resistors so no need for additional external resistors.
I will agree that when it comes to brake lights, it's probably not worth it as the light (color and brightness) is diffused by the red housing which negates two of the primary benefits of going LEDs. Faster light up is negligible and would only really be readily apparent on something like turn signals which crisp flashing versus halogen which powers up and powers down.
Old Mar 9, 2016 | 10:43 AM
TypeRx's Avatar
^^^great response, especially appreciated from a vendor/sponsor.
Old Mar 9, 2016 | 12:41 PM
AZN Optics's Avatar
Thumbs up
We'd rather lose a bit of sale, but gain a happy overall customer by offering honest guidance from an enthusiast standpoint.
Old Mar 9, 2016 | 12:59 PM
Dennis C's Avatar
Thanks for that information. I appreciate it.
Old Mar 9, 2016 | 04:36 PM
Franc01's Avatar
Franc01 has a spectacular aura aboutFranc01 has a spectacular aura about
Hi, What options do you have for the 997.1tt fogs in H3c?
Thanks,
Franc
Old Mar 9, 2016 | 06:00 PM
AZN Optics's Avatar
Thanks,
Franc
We have H3C HID conversion kits available. We're authorized direct retailers for high end Morimoto kits. Retail price is $150/kit. Plug and play canbus kit. Let us know if we can help.
Old Mar 10, 2016 | 11:23 AM
AZN Optics's Avatar
Shoot me a PM or email me directly at aznoptics@gmail.com and we can work out the details
