Why three washers for oil change?
Old Apr 3, 2016 | 12:33 PM
tomb18's Avatar
tomb18 is a jewel in the roughtomb18 is a jewel in the roughtomb18 is a jewel in the rough
Hi,
The first time I did my 997.1TT (2007) oil change I ordered the parts from SunCoast. The kit came with three washers. I could only find two drain plugs and all the DIYs showed only two places. So the third washer was mystery.
Now, I went to the local Porsche dealer to purchase the filter and the two washers and the parts guy says that there are three washers to change. On the parts diagram, one of the washers is on the top of the engine as far as we could tell. He asked a mechanic and the mechain said they always change all three.
Does anyone know what they are talking about?
Old Apr 3, 2016 | 12:55 PM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
You tube is a great source of info.....sure you will find your answer there
Old Apr 3, 2016 | 01:09 PM
tomb18's Avatar
No,
nobody talks about 3 washers. Only two
Old Apr 3, 2016 | 03:28 PM
AZ996TT's Avatar
AZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really nice
Originally Posted by tomb18
No,
No idea. I am pretty sure you only drain crankcase and dry sump tank. Should be different seal rings for each. 1 aluminum and 1 copper.
Old Apr 3, 2016 | 03:34 PM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
sure it's not two washers and one o-ring. There is a small o-ring on the filter cover.
Old Apr 3, 2016 | 03:39 PM
AZ996TT's Avatar
No,
Old Apr 4, 2016 | 09:08 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
I just checked service manual....
There is a sealing ring on the Oil drain plug on crankcase, another one on the oil tank and then another sealing ring on the oil drain plug on oil tank for turbocharger. So I am assuming at one point there was a drain that got phased out on the little tanks under the turbos.
I guess the 996 has this extra little drain as seen in this DIY page:
http://www.rmeuropean.com/porsche-99...il-change.aspx
Last edited by turboslut; Apr 4, 2016 at 09:20 AM. Reason: added link for 996TT DIY
NSX-Animal
Nov 18, 2021 06:35 PM
underpressure02
Mar 2, 2016 04:19 PM
spawnywhippet
Cayenne 955/957
Mar 1, 2016 10:31 PM
shreddedsessions
Feb 29, 2016 07:37 AM
Leslierc
Cayenne
Feb 25, 2016 05:05 PM
