997 turbo starting problem + rough idle
Old May 27, 2016 | 12:23 PM
Porschie997's Avatar
Porschie997 is infamous around these parts
I have quite often a starting problem with my porsche 997 turbo.
When turning the ignition key the first time, the car doesn't start. The battery is new and is certainly not the problem. But when I try a second time, it fires immediately.
Also there is an oscillating rpm immediately after starting and a rough idling thereafter (or even when driving at the same speed).
I suspected a faulty crankshaft sensor, but maybe someone has had the same problem and can help me identifying the problem for sure.
A video tells sometimes more then words. Here you can find 3 video's I recorded.
Old May 27, 2016 | 02:43 PM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Thats the fuel pump or at least in my case .
Old May 27, 2016 | 04:24 PM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
Did you end up replacing the fuel pump? Did you have to replace two on the TT or one? Do you recall how much parts and labor were?
Old May 27, 2016 | 10:12 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
That's definitely fuel related issue. How long is the car sitting when you experience this? What about when warm? Same symptoms?
Old May 28, 2016 | 01:59 PM
It depends. When the car isn't used for some days, I notice this problem. But when I shut of the car and try to start it again after 5 minutes it also happens.
Very strange, but it can be the fuel pump of course.
Old May 28, 2016 | 10:41 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Worth checking your MAF sensors and codes ...
Old May 29, 2016 | 05:20 AM
I will check my maf sensors.
I have an obd2 and there were no fault codes..
Old May 29, 2016 | 11:29 AM
yah996's Avatar
yah996 is infamous around these partsyah996 is infamous around these parts
Clean your MAF. I had the same trouble. MAF cleaner and some q-tips will save you lots of money. A new airfilter would make sense after cleaning.
Easy check, remove the cable from both MAF and start the cold engine. You will see.
Old May 31, 2016 | 07:55 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
for christ sake.
no q-tips. Don't touch the maf sensor wires. Just spray it off with Maf cleaner.
phantom works
Apr 1, 2016 08:24 PM
pdxm5
Mar 28, 2016 02:48 PM
shaunsak
Mar 24, 2016 08:05 PM
ExoticAffinity
Ferrari
Mar 20, 2016 08:57 PM
