Turbo removal/installation hardware kit?
Subscribe
Jun 14, 2016 | 03:43 PM
Hey guys....anyone know of a OEM kit similar to the following:
http://www.fvd.de/us/en/Porsche-0/-/..._997_1pc..html
Basically a new o-ring, gasket, nut for when you remove stock turbos and subsequently re-install different vtg turbos.
Reply
Jun 14, 2016 | 04:44 PM
Never seen anything like that. I just looked up all the parts and ordered them online. It was a lot less than what that kit is going for. The o-rings are a couple of bucks a piece and the gaskets can be had pretty cheap. The nuts are overpriced but you need to replace them if yours are original. Just be sure to order a few extra o-rings just incase.
Reply
Jun 14, 2016 | 05:08 PM
you wouldnt happen to have the purchase order with all the part numbers would you?
if not no biggie...I will piece together off of one of the OEM dealer sites and post all the part numbers for future reference.
Quote: Never seen anything like that. I just looked up all the parts and ordered them online. It was a lot less than what that kit is going for. The o-rings are a couple of bucks a piece and the gaskets can be had pretty cheap. The nuts are overpriced but you need to replace them if yours are original. Just be sure to order a few extra o-rings just incase.
Reply
Jun 14, 2016 | 05:31 PM
I can look. I had them all written down at one point.
Reply
Jun 14, 2016 | 06:01 PM
I think these may be the ones. just check.
the locknuts i believe are #99908420301
the exhaust gaskets i don't have but they are easy to find.
p/N: 99970761440 - Pressure pipe O-ring Left Size: 0 Color: 0
P/N: 99970738740 - RUBBER O-RING Size: 0 Color:
P/N: 99970178940 - RUBBER O-RING Size: 0 Color:
P/N: 99970758340 - Pressure pipe O-ring Right Size: 0 Color: 0
Reply
Jun 14, 2016 | 08:39 PM
thanks!
Reply
Subscribe
