coolant problem and coolant in oil
Absolutely. Misfires, boost pressure codes at least.
Ok.... I think I will ask them tomorrow how the come to that diagnosis cos my did not light up any check engine light , not sure about the boost as I wasn't driving ... Just warming it up in the parking
Thxs
Thxs
Given that you mentioned coolant loss with no visible trace of it, it's going into the engine. Which is 99.9% of the time, a headgasket failure.
Good luck and post back their explanation. I'm certainly interested to hear.
Op
Head gasket sounds trashed
Drop the Motor and do it right
Several reputable members here have told you that this is classic head gasket failure and the coolant loss and symptoms are not normal.
Yes I know it's typic head gasket
I'm going to talk with them today ask why they think it's the turbo !
It is possible its a cracked turbo .... They get very hot and could have been burning coolant so as not to see where it was going !
Obviously if it is the turbo it totally split when I was warming it up hence the smoke and the coolant passing into the combustion chamber
I will post some more later
Cheers
Ps
I respect your comment thanks for your input
Cheers
Ps
Cheers
Ps
Cheers
Ps
coffee oil (coolant+oil)=equals catastrophic failure. Regardless of where it came from all of your internals have had a nice bath in this goop.
attempting to put a band-aid on this situation will only cost more money, time, and aggravation in the end.
sorry to be blunt but would hate for someone to sell you some bad bill of goods only to end you back in the shop with cooked bearings a few days later.
Doesn't seem like he wants to face the truth.
2 months with internals bathed in gook. Regardless of what happened.
pull it and rebuild.... end of discussion.
