Updated Coils don't fit?
Old Jul 25, 2016 | 12:44 PM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Both Pelican and ECS are listing 997-602-104-02-OEM, as the proper coil pack for a 2007 turbo. They are quite a bit deeper than the original.
Note: Original design with 15 mm long bolt tabs, (uses 6 X 25 mm hold down bolts), When replacing original coils with updated design (997 602 104 02), longer hold down bolts will be necessary. Also use (Qty.) (2) 900 385 025 01 bolts (6 X 40 mm) for each coil.
I am having trouble reinstalling the passenger wastegate control, as the bolt head on the coil is hitting the wastegate.
Has anyone successfully installed this part number on a 2007 turbo?
Thanks,
Old Jul 26, 2016 | 08:37 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
I'm pretty sure those are the Berus that I installed without any issues.
Old Jul 26, 2016 | 11:24 AM
Webspoke's Avatar
Webspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond repute
On our 2008, the coil on the forward, passenger side, needed to be one of the older(shorter) ones to clear the right side turbo and its bracketry. When we ordered them at the porsche dealer that is what they supplied, with that caveat that certain VINs required that setup, 5 new, 1 old.
Old Jul 26, 2016 | 11:45 AM
SamboTT@ByDesign's Avatar
You can also use one bolt on the one coil and shave a few mm off the bolt hole on the other side where it touches. Both ways work.
Like M3 Maestro did, thanks for the pic bud ; )
Old Jul 26, 2016 | 01:01 PM
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
I also used loctite on the bolt. You should be good, done on many race cars for speed during any changes...not just Porsche.
Old Jul 26, 2016 | 01:27 PM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
That's crazy! I got the right parts and they fit perfect. Sand and grind and cut bolts...really bro?Anyhow, correct part number is this 99760210400 Vertex has them 37 a pop. Let me know how your "wrong coils" work for you in six months.
Old Jul 26, 2016 | 01:36 PM
M3 Maestro's Avatar
What are the "right" parts? I wanted the thicker coils, I wasn't gonna put in an old coil in that cylinder like most do. All I did was sand down that corner, that's it. No cutting bolts lol. That was my choice. Everyone should do whatever they are comfortable with, more than one solution here. If you think its a terrible idea don't do it simple as that.
Old Jul 26, 2016 | 01:43 PM
Al, this is a new thicker coil. Should be a "last time" upgrade especially for a high hp car as apposed to the standard thinner ones that seam to show fractures in between every plug replacement. Works great.
Old Jul 26, 2016 | 01:46 PM
Al Nunez's Avatar
Updated the post sorry it's above. Those coils are a mistake in Pelicans website. I brought to the attention of the site. It happened to me as well man. I guess Pelican parts didn't update. Anyhow, those are for the NON TURBO models.
JustDJR
Aug 11, 2016 12:01 PM
flewis763
Jun 25, 2016 05:54 AM
ECS Tuning - BMW
Mar 22, 2016 06:27 AM
msindi
Aug 13, 2003 10:33 PM
msindi
Aug 13, 2003 10:32 PM
