Methods to lower IATs
Old Aug 25, 2016 | 05:33 PM
longboarder's Avatar
I have Champion intercoolers and meth injection running 100% meth through a 3 gallon fuel cell/bladder with steel braided lines + aircraft fittings. No headaches, no worries, no leaks and 30 minute track sessions with IATs at or below ambient as I chill the meth before the event. Nothing is better. Not even a highly modified air to water intercooler (which I had on another car).
Cheers.
Old Aug 25, 2016 | 10:29 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
Cheers.
What's fuel cell are you running. Like the idea of a bladder but all of them have pickups in the top and are not gravity feed that I have seen.
Old Aug 26, 2016 | 02:58 AM
OK51MON's Avatar
OK51MON is infamous around these parts
Can I run meth off my current tune? Or do I need two seperate tune -one for one with and one without meth?
Old Aug 26, 2016 | 05:04 AM
Duckstu's Avatar
Duckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud of
You don't NEED a tune. You'd want to run smaller jets and less methanol. I run two 1.0mm jets for 75% meth / 25% water. When you run a 50./50 mix,.. you do more like two 0.9mm jets. You could run even smaller,.. and not re-tune,...and just get the benefits of the cooling. You could even run just water,.. or 75% water.
The methanol gives you extra octane,... but the water is what's doing the bulk of the cooling. Latent heat principal at work.
Perhaps running two 0.7mm jets with 25% meth / 75% water mix,.. and not tune would be my guess.
The system has safety's in it that shut down your boost if there is an issue with flow (either too much or too little). If you weren't "tuning" for meth,.. you could simply not connect that wire, and bypass the safety's. Then you could leave the system off most of the time,.. and only turn on the system on hot days or when at the track.
Old Aug 26, 2016 | 08:39 AM
Check it out. This one is sold by 6speed vendor Emanuele Design:
Old Aug 29, 2016 | 03:12 PM
LQQK's Avatar
Nice - I like the setup. Are there any issues with the pickup??
Old Aug 31, 2016 | 07:14 AM
Boosted TTS's Avatar
Boosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond repute
Champion IC's here with a Snow Performance meth kit running 100% meth. Running solid with no issues, thanks to Mitch!
Manuel
Old Aug 31, 2016 | 09:23 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Which kit is better? Snow performance or Aquamist
Old Aug 31, 2016 | 09:57 PM
These kits use plastic parts and cheap fittings that are prone to leaking/failure. Seen quite a few car fires and as a result, zero insurance coverage and some pretty pissed off people.
Pick one for the "brain" i.e. the controller (Aquamist is good but rather complicated and Coolingmist is best for simplicity and reliability) and use lines and fittings that the factory would use for a fuel system.
Old Aug 31, 2016 | 09:58 PM
No issues.
Old Sep 1, 2016 | 09:38 AM
I have the Snow Performance, with no issues...straight forward and simple to use.
Manuel
Modern Walker
Apr 10, 2016 03:57 PM
sharkster
Aug 27, 2003 05:16 PM
watt
Jul 30, 2003 07:23 PM
