Replace sport Chrono?
Old Oct 27, 2016 | 04:21 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Yes, that is what i am using the OBD-II gauge for, to let me know if I have a vacuum leak.
Originally Posted by Duckstu
In my last car I paid more attention to it in vacuum. I knew that at idle I should be pulling 18-20 inches of vacuum. If I wasn't (with the car at warm idle) I knew I was developing a boost leak and it was time to have a look-see under the hood.
Old Oct 27, 2016 | 06:41 PM
Kash Built's Avatar
5 Year Member
Kash Built is infamous around these parts
Here's my setup utilizing the oem glass and bezel.
Old Oct 27, 2016 | 06:49 PM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
Is that just a standard 52mm gauge? I Was thinking i'd take out the bezel and do a good 60mm gauge, but that looks really clean.
-Zach
Old Oct 27, 2016 | 06:57 PM
Kash Built's Avatar
5 Year Member
-Zach
Yes just a standard 52mm gauge. Still swivel too. I did this gauge because it shows both boost and wideband.
Old Oct 27, 2016 | 07:01 PM
zmw's Avatar
zmw
I would want a peak/hold boost gauge - the factory glass would be great to keep though. That looks like it belongs.
Old Oct 28, 2016 | 06:14 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Any functioning pics? How difficult was the wiring?
Old Oct 28, 2016 | 12:33 PM
pretzel's Avatar
pretzel is infamous around these parts
Wink
had the aeroforce.....went basic
Old Oct 28, 2016 | 12:44 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Love the basic VDO!!!! P/N Please
Old Oct 28, 2016 | 12:47 PM
pretzel's Avatar
Old Oct 28, 2016 | 02:39 PM
zmw's Avatar
zmw
more details? looks like you didn't use the factory glass, is the factory bezel still in there? the chronograh looks bigger than standard 52mm is why I asked - but for sure just a USABLE clock would be better than the stupid chronograph.
Old Oct 28, 2016 | 03:11 PM
808c2s's Avatar
Niiiice
Old Oct 29, 2016 | 09:34 AM
RickRST's Avatar
RickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to all
The OBD boost feed is very accurate, but only reads to 1.55 bar. It is the instrument cluster itself that is innacurate.
Rick
Old Oct 29, 2016 | 09:35 AM
RickRST's Avatar
I would like a standalone analogue gauge though for boost, but as OEM as possible.
Old Oct 29, 2016 | 01:00 PM
pretzel's Avatar
52 mm....similar to the other installs have to remove the sport chrono and use the old plastic bezel. Then find power, ground and a switched source for the illumination, all available under the wart.
Old Oct 30, 2016 | 10:12 AM
zmw's Avatar
zmw
does that wart come right off? If I remove the factory bezel is there still a way to mount a gauge? I'm wondering if I can get a 60mm gauge in there.
