Replace sport Chrono?
Old Oct 26, 2016 | 06:55 PM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
So I realize this might be sacrilege - but I think like most I NEVER use the sport chrono chronograph. Other than making sure it worked. All I really care about is overboost - Are people or have people either.
997.1 turbo
1. Replaced it with a functional gauge, I would prefer boost since frankly the factory "Gauge" is useless when tuned.
or
2. Replaced it with an upgraded unit that actually functions as a clock as well?
All I'd really like is some useful functionality out of it rather than an expensive looking dash wart. I'd be totally happy with an ACTUAL clock in there, maybe that's what I should do, try to find a nice little 60mm automatic clock to put in there
-Z
Old Oct 26, 2016 | 07:40 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
You can install an Aeroforce Intercceptor OBD-ii Guage in the sport chrono housing. Can have it display boost & a/f ratio or any other combo that the gauge support. That's what I did with my wart housing.
Old Oct 26, 2016 | 11:28 PM
Kash Built's Avatar
5 Year Member
Kash Built is infamous around these parts
I have an AEM wideband failsafe unit and i reused the existing glass and bezel so it had an oem look. The failsafe gauge shows boost and air/fuel.
Old Oct 27, 2016 | 06:20 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
pics?
Old Oct 27, 2016 | 07:44 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
Thats a great idea! How did you wire it? More info please
Old Oct 27, 2016 | 08:07 AM
Kash Built's Avatar
5 Year Member
Wiring was easy. It just powers up with power and ground. I'll post pics when I get some free time
Old Oct 27, 2016 | 09:51 AM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
^ Interested as well.
Old Oct 27, 2016 | 10:59 AM
mikestyle's Avatar
How does the gauge read the boost and AFR? Do you need to weld a bung for the censor? Or can you tap into the wiring harness/ obd?
Old Oct 27, 2016 | 11:11 AM
zmw's Avatar
zmw
reading off OBD will result in the same useless info that is displayed on the dash as far as I know, you'd need a real pressure sensor, probably coming off the FPR. As for AFR, not sure you might be able to use the OBD info for that. just not sure how accurate it is on the porsche.
Old Oct 27, 2016 | 11:21 AM
Kash Built's Avatar
5 Year Member
You need to weld a bung on the exhaust and run a vacuum line to the gauge also.
Old Oct 27, 2016 | 01:00 PM
mikestyle's Avatar
Thanks for the info guys! Having real time data like this can really put your mind to ease and also save your investment should something go wrong.
Old Oct 27, 2016 | 01:23 PM
808c2s's Avatar
I beg to differ. If that's true, then COBB and their Pro-Tuners are in trouble.
Old Oct 27, 2016 | 01:28 PM
zmw's Avatar
zmw
what is displayed in "boost" I believe is incorrect on the AP, they have set up a different table which measures actual pressure, not just relative - the simple ODB output would just be of the MAP sensor if it shows it at all. What you're reading on the AP is more than just what would output to an ODB type gauge.
Someone posted about this the other day, Let me see if I can find the post.
edit: https://www.6speedonline.com/forums/...ost-gauge.html
post 8 - now that would seem to indicate that with the stock sensor it might be correct though.
-Zach
Old Oct 27, 2016 | 03:24 PM
Duckstu's Avatar
Duckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud of
Well,.. the dash will only read to 17 psi,.. and the sensor itself gets saturated after 22.6 or thereabouts.
ECU's are able to map a bit above that as it can estimate the scaling above that boost level, as it mainly uses the MAF for fuel,.. and the all-important fuel pressure is done via a hose from the manifold to the FPR anyway.
But for sure the dash readout is useless. A real gauge would be nice.
In my last car I paid more attention to it in vacuum. I knew that at idle I should be pulling 18-20 inches of vacuum. If I wasn't (with the car at warm idle) I knew I was developing a boost leak and it was time to have a look-see under the hood.
Old Oct 27, 2016 | 04:19 PM
808c2s's Avatar
Interesting info. Yes, so an OBD-II gauge reader can give you a relatively accurate reading, perhaps not as exact as a dedicated boost gauge, but close? I guess if you're going above 22.7 psi, then the OBD-II may not be accurate anymore?
-Zach
