Cobb AP3 Boost Gauge
Old Apr 16, 2016 | 08:32 PM
Mkhan's Avatar
Mkhan is infamous around these parts
So I've been looking at the "boost target pressure" and "manifold absolute pressure" to determine my actual boost value and they do not seem to be the actual boost psi. Looking at the manual, it indicates that there's a dedicated parameter called "boost". I cannot find that as a variable on my log parameters. Any ideas ??
Old Apr 17, 2016 | 05:30 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
Manifold pressure is boost pressure. You get a negative reading under vacuum and positive under boost.
Old Apr 17, 2016 | 08:31 AM
Mkhan's Avatar
That's what I thought....it tops off at 22.6 psi n won't go higher when I know I'm making more
Old Apr 17, 2016 | 08:58 AM
ctony66's Avatar
I believe (but not positive)You need cobb's Pressure sensor to read higher. The stock doesn't go that high.
Old Apr 17, 2016 | 09:45 AM
Mkhan's Avatar
Yep...I've got a Bosch 3-bar MAP Sensor from PTF....weird
Old Apr 17, 2016 | 10:33 AM
ctony66's Avatar
22.6 is above average from what I have seen. I only see 20 on a good day (ots cobb stage 2). Who did your tune PTF?
Old Apr 17, 2016 | 01:18 PM
Mkhan's Avatar
I'm on a custom tune. Working with one of the Cobb guys.
Old Apr 17, 2016 | 02:14 PM
proTUNING Freaks's Avatar
proTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond repute
Hey guys, for the boost values you'll need to look at a different pressure channel (Boost Pressure Corrected) when switching to a 3bar TMAP sensor.
When running the OEM TMAP sensor you look at the pre-throttle pressure channel. Manifold pressure channel is just a calculation based on an internal model on the 997.1 Turbos. There's no TMAP sensor in the intake manifolds on the 997.1 like on the 997.2 and 991 turbos.
Let me know if I can help in any way.
Dzenno@PTF
Old Apr 17, 2016 | 02:25 PM
Mkhan's Avatar
Dzenno@PTF
Thanks Dzenno, will log it n see what happens!
Old Nov 6, 2020 | 02:39 PM
lopov1972's Avatar
lopov1972 is infamous around these parts
Hi, same Problem on my 997.2 Turbo. I install the cobb stage 2 100 octane map and cant find the live boost gauge..
TheBozz
Oct 4, 2018 10:53 AM
spinecho
Apr 26, 2016 05:57 PM
NMSV8V
Mar 31, 2016 08:05 PM
Harris@TPCRacing
Mar 25, 2016 07:06 AM
