-Build Thread- 997.2TT by ESmotor
Old Dec 20, 2016 | 03:37 PM
  #76
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
Originally Posted by iLoX
Hurry up already, i wanna see those vbox figures, this is worse than waiting for Santa to arrive
Hahahahahaha
I'm awaiting my tuner Emre to update the tune
I'll keep you posted.
The current 60 to 130 as of tonight is 6.5 seconds
Not updated tune
Old Dec 20, 2016 | 03:38 PM
  #77
3llooi's Avatar
Originally Posted by porschecayenne92
your car deserves some lighter wheels now
Yes sir!
BBS FI are ordered last month
But they will arrive mid January.
Old Dec 24, 2016 | 05:03 PM
  #78
3llooi's Avatar
Update
Still the car is under fine tuning by the champ Emre
I'll report results the soonest
Old Dec 25, 2016 | 07:13 PM
  #79
3llooi's Avatar
Update:
so now I have preliminary vbox results
I know for sure I can better them!
as the road was not the smoothest and Aquamist might need some fine tuning
Old Dec 25, 2016 | 07:36 PM
  #80
jazzwu's Avatar
jazzwu is a jewel in the roughjazzwu is a jewel in the roughjazzwu is a jewel in the rough
Originally Posted by 3llooi
Update:
5.89 seconds 60 to 130 mph vbox confirmed.
wow thats moving! Pump fuel? That time already destroys full bolt on GTRs on e85 hahaha
Old Dec 25, 2016 | 07:41 PM
  #81
3llooi's Avatar
thanks mate
I have the feeling we will do better
fuel is VP racing MS109
after we are all done with the best tune on 109... we will do a pump gas tune
Old Dec 25, 2016 | 07:46 PM
  #82
jazzwu's Avatar
thanks mate
ah okay cool so race fuel. I bet once dialed in, you can probably do low 5s 60 to 130 mph. And that will be amazing.
all on stock pdk clutch pack and fuel system.
Old Dec 25, 2016 | 08:00 PM
  #83
3llooi's Avatar
Thanks bro!
Yeah... I hope we hit low 5.xx seconds
I'm using MS109 fuel because we really have crappy fuel!
And this will be my race tune
Emre will do me another tune for pump gas
Old Dec 26, 2016 | 03:34 PM
  #84
3llooi's Avatar
Originally Posted by mcoupe mus
Awesome results so far.
This setup isn't just about the numbers though, it is a serious weapon on the rod with this kind of power delivery.
Will be hard to beat in most situations!
True and well said bro
But the thing is that numbers attract us since it's the tangible way of feeling results
Car started with 7.7s 60 to 130 mph.
With exhaust and cobb ots tune
Tonight I've tried the car at the drag strip in Bahrain just for fun
Made 10.230s for 1320ft at 220kph speed
Not bad
Old Jan 11, 2017 | 03:06 AM
  #85
3llooi's Avatar
Originally Posted by IMI A
You my friend are miles ahead of me so I should be taking advice by you. My tuner has suggested main things are:-
- do not place the injectors in any hoses - might seem obvious but have seen it many times before - if you get a boost leak on a turbo to intercooler hose etc or intercooler to y-pipe you will be spraying methanol over your engine!
- put the injectors far enough back on the y-pipe so it has time to turn to a vapour
- set up the control based on injector duty cycle not boost - IDC is always okay but if you have small boost leak then by boost you are affected
- make sure you set the IDC low enough so that when you need the meth, it will be in the cylinders
- keep all the lines away from anything hot
- run with water first to make sure it is leak proof - then when sure run Methanol
- run with a large enough tank - 9e use 2.2 gallons
- use the sports chrono to mount the gauge
After a chat with Richard at Aquamist.co.uk, it's really important also to mount the jets correctly and not through a thick walled charge pipe or bung... that would make the spray go to dripping and not the best !
I'll be getting extended tall jets to help.
Old Jan 11, 2017 | 03:45 AM
  #86
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
Your car is really moving forward very fast.
Can you give more info about the correct/optimum way to mount the jets?
Can you also post some 100-200kph numbers for european folks?
Old Jan 11, 2017 | 05:17 AM
  #87
3llooi's Avatar
I'll post a good diagram for mounting the jets. Aquamist will send it to me.
Results are here:
click
We are still tuning the car... do I am sure there is little more room lol
Old Jan 11, 2017 | 04:46 PM
  #88
3llooi's Avatar
Sent to me now by Aquamist.co.uk
I guess I'll move to extended jets as I've bungs welded to my ypipe
Old Jan 12, 2017 | 10:57 PM
  #89
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
Nice Build!
Old Jan 19, 2017 | 03:29 PM
  #90
3llooi's Avatar
Originally Posted by machinegunt
Nice Build!
thanks!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
