Ams coolers with stock turbos
Old Jan 30, 2017 | 08:22 AM
Brooklyn boosting's Avatar
Brooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond reputeBrooklyn boosting has a reputation beyond repute
Id like yo know who's running AMS intercoolers with stock turbo. Seems like my turbo outlet pipes keep popping off because of those stupid plastic clips does anyone have a better solution . I know outlet pipes are made for GT 30 turbos there's got to be a better solution instead of the stupid plastic clips
Old Jan 30, 2017 | 09:28 AM
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
I popped mine off 1 time as well, this is definitely an opportunity for the AMS kit. Other than that it has been flawless and my intake temps are always low and stable.
I believe forum member Roe fixed this by using the adapter section he cut off the stock hose. I believe that cured the issue for him. If I recall correctly he runs around 22-23psi throughout the entire engine speed range. Maybe he will chime in.
Old Jan 30, 2017 | 09:40 AM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
AMS has an update that eliminates the plastic ring. I have not installed mine yet.
Old Jan 30, 2017 | 09:42 AM
M3 Maestro's Avatar
good to hear as I was about to order another set of plastic rings for my new Proto VTG upgrades. Thanks for the info!
Old Jan 30, 2017 | 10:01 AM
I broke several of these as well, first one broke when installing them for the first time
#TeamAIM
Old Jan 30, 2017 | 10:08 AM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
contact AMS - they have eliminated those rings because of that - We broke 4 of them between installation and dyno tuning my car, they kept popping off and or breaking under load - they really should have been made out of bilet, or a single piece silicon which is what they switched to.
Old Jan 30, 2017 | 10:20 AM
Ams did such a bad job on those clips they should really step up and give those out for free... for the member that has that pic can you please give more info on how much you paid and a better shot of adapter... do you have to get new hose or is it a plastic piece... really pissed right about now..
Old Jan 30, 2017 | 10:22 AM
I would assume they are.
#TeamAIM
Old Jan 30, 2017 | 10:32 AM
elite1's Avatar
No charge. Shoot them an email or give them a call. Make sure to use some t-clamps regardless. Don't use they clamps provided.
Old Jan 30, 2017 | 10:37 AM
elite1's Avatar
Ohh Sorry, No adaptor. Hose is now a smaller diameter with a molded ring/lip inside.
Old Jan 30, 2017 | 10:44 AM
When did you get those how long ago
Old Jan 30, 2017 | 10:51 AM
I ordered new hoses in sept they should of least had the honesty of saying that new updated version is comming out..
Old Jan 30, 2017 | 11:00 AM
elite1's Avatar
First week of January. Was doing a cat conversion and rings were melted with only a few casual drives.
Old Jan 30, 2017 | 11:02 AM
M3 Maestro's Avatar
same failure mode as mine
Old Jan 30, 2017 | 11:29 AM
SamboTT@ByDesign's Avatar
AMS has been really great and responsive about this so kudos to them!
