Spoiler Hardware
Old Mar 3, 2017 | 06:33 PM
Kricci's Avatar
Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !
Spoiler Hardware
Anyone know how to remove these 2 pieces on the bottom of the OEM spoiler where it attaches to the rams? I'm out of ideas...
Old Mar 3, 2017 | 08:53 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Good question, they might be epoxied in? Why do you want them out?
Old Mar 3, 2017 | 09:00 PM
Kricci's Avatar
that is starting to be my theory as well...
To install in/on a new spoiler.
Can't seem to find a part number for them either as i was just going to buy two new ones.
Car is looking a bit naked currently:
Old Mar 4, 2017 | 11:32 AM
Kricci's Avatar
Well i got it off... things i learned:
They use a ton of loctite on the thread. It takes a ton of force... we messed with it for awhile before it finally came free...
The bolt is soft metal the hex shape at the bottom will likely become rounded.
Probably best to let a bodyshop handle this honestly...
Old Mar 14, 2017 | 06:28 AM
So you can use a hex head socket to twist it out?
Old Mar 14, 2017 | 11:22 AM
Kricci's Avatar
yes, however it is not easy and you should plan on it stripping...
Old Mar 16, 2017 | 10:55 AM
Just looking for the info in case I get a customer that needs to move the bushings over to an aftermarket wing. What size hex wrench was the socket? I know these parts are NOT available from the dealer, at least the similar part for a 996 turbo. We have to custom make them.
Old Mar 17, 2017 | 07:23 AM
Kricci's Avatar
Yeah, Porsche doesn't sell them as separate parts for some reason.
It was a 6 I believe. However the metal is very soft and with the torque needed to break it free, it rounded very easily. After rounding almost completely I think we actually got it removed with a star shaped torx bit.
Old Mar 17, 2017 | 07:25 PM
yeah, only way to get them is to buy a new wing for $5400. http://www.sunsetporscheparts.com/po...t_name=spoiler
Old Mar 18, 2017 | 12:30 AM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
^ Ha....that's just for the wing blade. The rams (complete Drive Unit) is another $2,700!!!
