2008 Turbo 42k Question About Engine Removal on CARFAX
Old Mar 28, 2017 | 02:17 PM
tjg81296's Avatar
tjg81296 is infamous around these parts
Hi All -
New here. Wonder if anyone would have any thoughts on buying a used 2008 911 Turbo (42k Miles) with this in the Carfax report at around 40k Miles:
"A/C compressor serviced
Air filter replaced
Antifreeze/coolant checked
Antifreeze/coolant flushed/changed
Coolant bypass pipe/hose replaced
Cooling system bled
Cooling system checked
Engine removed to complete repair
Engine/powertrain computer/module checked
Oil pressure sender/switch replaced"
Would it be normal on a 997 to pull the engine for some servicing? No idea what the issue was as I am reading this in a Carfax report and no other glaring issues that I see. It's a 6sp manual so I would send the car for a PPI and get a DME report. Any other advice is welcomed!
Thanks, Tom
Old Mar 28, 2017 | 02:21 PM
tjg81296's Avatar
Wrong Forum - Reposted in 997
Mods please delete, Sorry
Old Mar 29, 2017 | 05:18 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Yes, some procedures require the engine to be dropped for access.
DC
Old Mar 29, 2017 | 08:11 AM
dave29's Avatar
dave29 is just really nicedave29 is just really nicedave29 is just really nicedave29 is just really nicedave29 is just really nice
I had the motor on my 2011 GT3RS pulled at 7500 miles to replace coolant lines, pin the hoses and install Sharkwork elbows. Pretty common
Old Mar 29, 2017 | 09:14 AM
tjg81296's Avatar
Thanks!
Old Mar 29, 2017 | 06:17 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
The camshaft replacement issue requires pulling the motor
Old Mar 29, 2017 | 09:01 PM
maverick997's Avatar
maverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to all
I had a coolant "T" at the rear of the engine rupture at 3500 miles....they had to pull the engine to get to it.
Old Apr 3, 2017 | 06:50 AM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
a knowledgable shop can drop the motor on a 997 turbo in a few hours, and it's just easier to work on that way - if they had to do the coolant pipes and other things then yes the motor came out.
