Is the Metzger reputation overrated?
Without opening up the motor:
Some are saying that after 650lbs of torque, the rods are at risk of bending, which is 50% more than stock at the wheels. That doesn't sound especially robust.
I understand that sudden spikes in torque and how the power is delivered reduces risk, but if the rods can "only" hold ~650torque reliably AND cost $7-10k to replace, doesn't that make the strength of this motor overrated?
Lets ignore the racing and heritage of the motor for this discussion, because that's not what I'm asking.
Even from Porsche, aren't the new 997.2 and newer Porsche motors all doing that? I haven't looked it up
I would say DRY SUMP means a lot, the fact that this engine is so stable and reliable, doesnt overheat (yes 26-28liters of cooland work nicely), also can be very easy upgradable to 1000wph RELIABLE - with only rods, head studs and gasekts - maybe 2-3000$ kit+labour, put some aftermarket coolant pipes and have no worries after
I have both a r35 GT-R and 996tt, yes the gtr (VR38 engine) is also upgradable, but I would take the mezger anytime for any non drag racing related setup
the new 997.2TT/S, 991.1/2 TT/S arent real dry sump, if going to use them with slicks just take care, other than that I see no draw back.
I did weld my coolant pipes this month
probably not over rated. engine strength not just measured by rods. what about cases that can do 1500+ or pistons and cylinders that can do 1000+ or stock heads and cams that can make a 900+. how about an oiling system that keeps the pressure rock solid to 8000+ rpm, oil cooling as well. lots of factors here. rods that hold more torque weigh more so they are not used in a car rated at 480hp, more wear on bearings, crank, pistons, wrist pins, crank itself..... don't forget these things were meant to be able to run for 200k miles. none of this is to say that the new 9A1 engine isn't good because it is good, very good.
GTR rods fail around the same torque as the Porsches, maybe even 10% less.
#TeamAIM
#TeamAIM
Take a look at my signature and I sure can suggest a few Toyota and Nissan engines that can, but lets not turn this thread into that.
I believe the Mezger unopened record is 962whp? Regardless there are tons of cars running around making 650-700whp on stock motors, add back the drivetrain losses to the whp figures, and you have 900BHP stock motor cars running around just fine, I would say the Mezger engine reputation is well deserved and far from overrated.
What kills these motors, and mostly other tuner motors, even the "Indestructible" 2JZ is torque. As the turbo technology advances, these cars are getting faster and faster every 5-10 years, more power and less lag coming from smaller turbos, results in more available tq down low. If you have one of these turbo setups on a stock motor, I would make sure your tuner is aware to bring the tq on slowly in the low rpm range to be easier on the rods.
On a stock motor, I would be more afraid of a big VTG setup on "kill" using ethanol than a much bigger GT3582r 93oct tune setup.
The 2JZ is strong, but it is not bulletproof as some think. I had a 2JZ on the dyno that a stock rod let go at 800 nm @ 4000 rpm.
I believe keeping control of tq is the key to keep the rods happy.
and the stock head flows 75-80% of stock 996TT heads.
#TeamAIM
#TeamAIM
modding for huge hp is a fools errand anyway. A mildly modified (tune, exhaust, intercoolers, boost tubes) 997TT will be tons of fun and should last forever. i'd say the mezger earned its reputation for reliability when raced, not necessarily that it made 60 gazillion hp.
I assume this is based on raising turbo boost?
In general you cannot damage the rods and the crankshaft with more boost. The additional boost only applies when the rods are in the position where they are most robust. You can damage a lot of other stuff with more boost (and the resulting more power, and more torque, separately), but not the "core" cranking.
It is also different to create "sudden" spikes in torque from a turbo or supercharger. Maybe the above quote is not about turbos?
I know a few people that have Mclarens and to be honest they are in the shop more than the road. Some are earlier MP12C models so I am not sure if they have sorted out the issues with the newer models. None the less I would say he Porsche is much more stout and I would worry a lot less about a 911 breaking than a Mclaren.
I thought that some Chevy LS motors, Viper, Supra, and heck even the S2000 motor all seem to be ok with pushing beyond the 50% over stock power on stock internals. But that's my opinion and not actually pulling research out for specific figures
According to Porsche launch literature for 997 turbo stock we get approx 500 ft lbs of torque from just 1950 rpm. On the stock set up which I ran for 8 years and 60,000 miles whilst the turbo was a daily I never felt I got any meaningful torque till about 3000rpm. In fact may sound strange but I got more torque spike on stock set up than on current bigger hybrid VTG set up. Pretty sure on current set up my torque is pegged back to something like 580ft lbs in non sport mode and 640ft lbs in sport mode. Have a dyno of the pump tune somewhere if you want to see it. Peak torque hits much later too at circa 4000rpm but theres good torque everywhere. On a turbo powered engine your tuner can basically model how much torque he wants and how / where in the rev band it comes in.
Mezger is a good engine. McLaren the only other manufacturer making engines of similar quality i.e. true dry sump designs with fully serviceable racing block. Having said that I blew my stock engine on a long high speed run at 175mph once! A tuner hadn't been anywhere near the car when that happened. A liner just melted after 5 odd mins of high speed running in 6th gear.
I may be wrong but I don't think the new 2017 991.2 turbo S has a proper dry sump engine? Is this correct?
So aren't the post Metzger motors on Porsche Turbos all handling the same or higher power levels? Seems like there's a bunch of 997.2 cars and 991 cars that are running 9 second quarter miles on stock internals
