Sponsored by: Bears Transport
Quick Q - Bigger Injectors
Old 02-22-2018, 04:40 AM
Bargo's Avatar
Bargo is on a distinguished road
Did some searching but wasn't able to find a conclusive answer.
Currently have stock turbos and a softronic tune, seems like the stock injectors are able to keep up with the boost increase, but just want to make sure that I am not hurting my engine by letting it run more "lean" as the stock injectors may be struggling to keep up? Would it be helpful to have larger aftermarket fuel injectors? Would this help with the linearity of the power, especially at higher RPMs?
B
Old 02-22-2018, 07:48 AM
997TurboTom's Avatar
997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !
Someone correct me if I'm wrong, but running some logs or dyno pulls and reading the air/fuel ratios is the proper way to check if you're running safe levels of fuel pressure
Old 02-22-2018, 07:46 PM
mr dw's Avatar
mr dw has a spectacular aura aboutmr dw has a spectacular aura about
Is this on a 997.1 or 997.2? I would suggest logging injector duty cycle, air fuel ratio, and fuel pressure.
Old 02-23-2018, 02:05 PM
Softronic's Avatar
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
B
Hello all our files made for the stock Turbos from the 996TT,997.1TT 997.2TT and so on do not require different injectors. Different injectors are used when changing the turbos or increasing the boost pressures outside of the stock tuned setting and so on. You can give us a call should you have any further questions.
Best,
Scott
Softronic - Porsche Performance Software Tuning
Faster than a speeding bullet.
Cayman | Boxster | 911 | Cayenne
Like us on Facebook for updates and promos
24HRS Daytona Winner programmed by Softronic!
Porsche Interseries programmed along with teamed owned Tudor and World Challenge cars in an exclusive with Softronic.
Porsche PCA racing binary check by Softronic for compliance.
Old 02-24-2018, 09:36 AM
Bargo's Avatar
Thanks for the reply Scott. Had another question as well, I will PM you!
Old 02-25-2018, 09:43 AM
hichamaziz's Avatar
hichamaziz is an unknown quantity at this point
Old 02-27-2018, 07:32 AM
the one sure way to know if you are out of injector.
#TeamAIM
Old 02-28-2018, 04:10 AM
Cobrajet's Avatar
Cobrajet is an unknown quantity at this point
Yup...injector duty cycle. Try to keep it under 85-90% WOT so you have a little headroom.
johnspeed
06-12-2014 08:35 AM
dgreen78
07-05-2007 11:52 PM
BlackBear
12-01-2003 01:41 PM
Quick Reply: Quick Q - Bigger Injectors
