What could have done this to my wheel?
Old Jul 28, 2018 | 02:59 PM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
While swapping wheel/tire sets today I went to clean this black wheel I just took off and noticed this etching down the inner barrel center. The wheel was just freshly painted 2 years ago and certainly didn't have this marking after the pain job, but I am questioning if it was this last 5-6 mos of use on the car that did it or if I could have been prior. This did not happen on the opposite wheel while on the car. I did one autoX and one track day with PCA in the winter/spring. I'm dumbfounded.
The only thing I did not do was slap the wheel back on just to inspect clearance to the brake caliper. I had already tightened up the other set to the car and only saw this as I was cleaning the black wheels prior to stacking them up.
Thanks,
Old Jul 28, 2018 | 11:15 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Rock, stick, or twig, stuck in between your caliper and inner barrel, or rubber "clag" build up. Not uncommon.
Old Jul 29, 2018 | 09:41 AM
Yes thanks. 1st time Ive had that and your input is confirmation on what others have said. WOW!
Old Aug 1, 2018 | 08:09 AM
rock jammed between the caliper and the rim
#TeamAIM
VTBigYellow
Dec 22, 2010 04:32 PM
d.s
Oct 11, 2004 01:28 PM
